That's the way I roll (or brush in this case)!
Jason Roehl in Lafayette, IN
Unless it's just an absolute emergency on my part, natural bristle brushes don't see waterborne finishes ever. Even for oil-based finishes (which I very, very rarely use), I typically use a nylon/polyester blend. Heck that's almost exclusively what I use. Once in a while if I have to do a trim package by hand, I might pick up a 100% nylon for the softer bristles and better overall finish, but that also depends on how thick the paint is. If it's very thick--and many paints are trending that way to meet VOC requirements--then softer bristles don't work as well. They just can't hold the weight of the finish.
I agree with the suggestion to use brush cleaner, though. It's about $10/gallon or so, and is just a nice little solvent cocktail that will at least soften most common finishes if not outright dissolve them. Like someone else said, let it soak in the brush cleaner overnight, up to the ferrule, but suspend it if possible rather than letting the brush rest on the bristles. Wash it, scrub it, comb it out, then repeat the process, making sure you get the brush cleaner worked into it up near the ferrule.
In my case, I like a good brush as much as the next guy, but it's not always worth my time to deal with them if they get too nasty. I don't want to think too much about what I've spent on brushes over the last 15 years. The number easily surpasses 4 digits.
Jason (painter by day...and sometimes, night).
