200+ woodworking book reviews
Crown molding on table saw
David C.
For those who may be interested. I've developed a calculator for cutting crown molding on your table saw. It hasn't been thoroughly tested so I hope it works. Simply enter your height and depth dimensions and the calculator should return to you two angles for bevel and miter settings. You'll find it at www.magellanpcb.com where you'll find a link at the bottom of the page to the calculator.
Dave
Re: Crown molding on table saw
(Message Deleted by Poster)
Chuck Lenz
Re: Once again ...
David C.
I know. It's insane! Please, somebody stop me!
Hey Chuck....
Nat Robison
On this point, you seem to have a big problem with people who use a TS for something you'd choose to use a Miter Saw for and I've seen you comment on it several times.
If something can be done as safely (or at least, no more dangerously) on one machine vs. another, what's the downside?
I looked up the link the original poster was referring to and it was devised by a guy who doesn't own a miter saw and figured a way to do it on the TS. By the way, it appears he did more mathematical computations to figure it out than I've done in my entire life.
I'm just curious as to your thinking..........no malice intended.......just wondering.
Chuck Lenz
Re: Nat....
David C.
Chuck, sorry about the smart aleck answer. It was uncalled for.
I should have said that somewhere on this planet there are probably hundreds of people at this very moment trying to cut crown molding on a table saw with less than desirable results. I devised the formula just for fun. If someone finds it useful, all the better.
Re: Once again ...
FredD
Why would anyone cut Crown miters on anything except a Miter saw (chop Saw) it is so much faster and easier and accurate, ;-))
On the other hand , for picture frame stock and Step moulding, I use a sled on a Table saw........
FredD
