spruce
Joel M. Burki
Hello, I am building a custom frame for an early Salvidor Dali work and need four lengths of spruce, or other light wood, 4" X 6" X 4'. Any ideas of where to find? Thanks, Joel.
spruce
Joel M. Burki
Where spruce lurks...,
Lee Grindinger
Spruce is available in most lumber (look under hardwood) sellers yards. It's sold as framing lumber under the labeling of SPF (Spruce Pine Fir) and it is cheap here if you can sort for decent stock, then finish drying it which spruce dries quickly and easily. Instrument makers use spruce so check with one for where he gets it if you know any or make a call or two from the yellow pages.
Consider basswood, it's cheap and available in most hardwood lumber yards and poplar may work for you as well.
Lee
Re: spruce
Richard
Go to http://www.woodfinder.com/ and type in Sitka Spruce and your zip code.
Re: spruce
Jim Hoeller
Try Hibdon Hardwoods in St Louis, MO. They have very high quality Sitka spruce suitable for musical instruments.
