Invention?
Invention?
Invention?
Jim Abplanalp
Is this an invention or has every one beat me to it?
Build this and you will quit using your Miter Gauge Stop for cross cuts and even the Compound Miter Saw for square cross cuts. The cut is as accurate as your fence tape. If you want to shorten a 6 foot board by 1 1/8 inch just set the fence to 3 1/8 inch, and use the CUT OFF leg. If you want a piece 15 � long just set your fence to 17 � and use the OFF CUT leg.
After more than an hour (awake late at night) I had an idea which I will call my Gizmo. The idea is to eliminate the fence with stop on the Miter Gauge (with set up error) and the error of the CMS. The theory is to create a known distance between the TS fence and the blade and at the same time make cross cuts safer by reducing kickbacks. It also makes it much quicker and more accurate to set up the cut than on either the Miter stop or the CMS.
After about � hours of research and development I built the to the following specs. NOTE that the Gizmo must be made with legs more than 2 inches long before trimming. You might even make the assembly long say (12 inches) and cut it into units of 3 inch width. Note the red on the cut off to reduce errors in application.
NOTE you will have to make a new if the blade is changed thick to thin etc. or if the fence curser is adjusted to the fence tape. I also suggest that you place the Gizmo at the same position on the fence to eliminate any small error introduced by the fence being pitched away from the blade. I now have two, one for the 12� blade and one for the 7 �� blade.
This is then used as shown in the following pictures.
And affixed to the fence with my $1.99 clamp (note the great graphics).
The only thing the research team could come up with for a method of creating the CUT OFF leg of the Gizmo is to sneak up on the kerf by adjusting the fence in small increments and clipping a piece of scrap to make a notch and measuring. Then passing the Gizmo thru the blade.
The cut OFF CUT leg is easily done by simply setting the fence to 2 inches and sliding the Gizmo through the cut. Be very careful with these cuts.
Re: Invention?
(Message Deleted by Poster)
Chuck Lenz
Re: Invention?
Re: Invention?
George, Oxford, nc
I use something similar. I have a 2" x 1" x 8" block of hard maple. I set the fence either 1" or 2" longer than the piece I want and put the stick between the work piece and the fence. If I change blades I adjust the cursor and I don't have to worry about adjusting the stick. At the start of each shop session where I will be working with the table saw, I check/adjust the miter gauge to the blade for perpendicularism.
George
Re: Invention?
Re: Invention?
Marv
Chuck,
When I bought my Unifence many years ago, I got two of the aluminum fence extrusions. One is the long one, the second one is only about 8" long. The short one is for crosscutting.
Marv
Re: Invention?
Chuck Lenz
Re: Invention?
Re: Invention?
I've made one also but mine extends 6" out from the fence. I had really bad kick back one time while cutting 3" square blocks using a 3/4" board clamped to my fence as a stop while using the miter gauge. Apparently a 3" square block is longer than 3 3/4" when it vibrates and rotates sideways. It hit me in the chest so hard it almost knocked me down. I now have a 6" space for cut offs to go into.
Re: Invention?
Re: Invention?
Virgil Johnson
I have a steel 123 block I use for cross cutting with the rip fence for a stop. 123 meaning 1" x 2" x 3". I use the 1" side for crosscutting. I just set it on the table and don't need a clamp.
Re: Invention?
Re: Yes Marv...
Alan in Little Washington (NC)
I made a short cutoff block/spacer for my Unifence whose width is the exact distance between the vertical and horizontal fence cursor marks. I attach it to the vertical fence so I can use the low fence cursor to set the cutoff.
Re: Invention?
been there ...done that
bill tindall
While your device is much more elegant, I have for years kept a "c" clamp and a simple 1" block of wood on the shelf by the saw to do tasks like you describe.
However, this arrangement is not going to replace my miter gauge stop. If one needs to cut a multitude of pieces say 24" long I want the 24 " piece firmly under control against the miter and the smidgen I am cutting off to be on the other side of the blade as the off-cut. If the off- cut was to be the precise 24" cut it would be left bouncing against the saw blade as a cut-off. Not the most desirable situation.
Re: Invention?
Re: Invention?
AZ in Colorado Springs
3x3 square: the diagonal measurement is nearly 4-1/4. Ouch !!
Re: Invention?
Leo Cuellar
Re: Invention? Different method.
Leo Cuellar
Out of concern for kick backs when cross cutting I offer another solution. If you have 2 miter gauges, you can set the stop rod on one for your off cut and use the second gauge to push it through the blade. Just leave the stop gauge well back from the blade. This works very well for multiple short pieces. No RIP fence involved.
Re: Invention?
Rick L
Re: Improvement
Rick L
I made one similar 35 years ago but used 10" so there is less of a math compensation problem. For 12" crosscut I set my fence ar 22". Also with 10" you can crosscut much shorter pieces. Hard to explain but my miter gauge rides up past the crosscut fiture so I can set my fence at 14" and crosscut a piece at 4". There's very few new ideas out there. Just new people discovering old ideas.
Re: Invention?
Re: Invention?
Alan S
The new part of it seems to be the two different blocks that differ by the thickness of your kerf so that you can easily measure to either side of the blade. I like that.
Re: Invention?
Re: Invention?
David Hay Denver
FWIW, I was just looking through the latest WOOD magazine last night. In an article about cross-cutting on the table saw, they have a jig/stop block that looks very similar to yours.
David
Re: Invention?
Re: Invention?
Jim Abplanalp
You are right � no one seems to have gotten the root values of the device.
(1)The setup time for the cut should be less than 5 seconds.
(2)The accuracy of the cut is exactly the same as the accuracy of your fence tape and your eye.
(3)The �two way� block is merely a bonus.
It is not intended to be a safer way (to avoid kick back) when cross cutting
If you are concerned about kick back make the �legs� longer and if you are really concerned about kick back mount a 7 �� blade.
Clearly a poor choice of title (Invention?) note the ? I know well it is not an invention.
