Acceptable tolerance of flatness for TS tabl
BradPA
What is an acceptable tolerance of flatness for tablesaw tables?
I purchased a new Unisaw (but the old model) last fall. Because of busyness of life including a new baby, I am just now assembling the extension table to the saw. I am having a heck of a time lining up the edge of the extension to the saw table. I then measured with a straight edge and feelers and found the tablesaw table from the infeed side to the outfeed side and the outfeed is 0.015 out of flat and lower than the infeed. So I am having trouble lining up the entension table without a bump on the rear.
I could probably shim the extension table to be out of flat to match the tablesaw, but I am not sure I like that solution. Before I call up Delta, I was wondering what level of flatness is acceptable?
Re: Acceptable tolerance of flatness for TS tabl
Clint Searl
Clint Searl
What difference does it make when you run a board through?
Clint
Keith Newton----Little Rock, Arkansas
There is nothing wrong with wanting it to be perfect, but this will not have any effect on your work. Most of the plywood that you run across that top will likely be bowed 1/4 ~ 1/2".
Thomas
Can you tighten down the middle, and put a clamp on either end, then tighten down each end that way? I think you can force it to match the main table.
John McGaw
It doesn't sound as if it will be a problem, at least for an outfeed table. You certainly wouldn't want the outfeed to be higher than the main table for the obvious reason that it would interfere with passing a flat board (should such a thing truly exist) across the tables. When I built the folding outfeed table on my Robland the one thing I made sure of was that it was out of the way and, although I know that it is lower than the main table, I have no idea how much. Since it made from wood products it moves all the time but it probably never gets as close to flat as yours is now.
Maybe I'm way off base, but...
doug f, san clemente, ca
if I'm reading correctly, your outfeed table is a bit below the actual table saw. If that is so, my opinion is to leave it. I build my outfeed table so that it is about 1/8" below the table saw level on purpose so that long pieces would slide easily after being cut.
If I'm reading this wrong then judicious use of the delete key is in order.
Doug
Leave It Alone and Use It
FredD
If your talking about the cast iron table extension and it doesn't line up ,by all means call Delta.
It is not acceptable anywhere I have been to have to remanufacture a new machine to get it to work well. Call them. In any case do not try to force the cast iron table wing into lining up , you will more then likely crack it.
FredD
Marv
"Flatness" is not the proper word in your situation. Alignment might be a better word.
If the two surfaces were exactly even that would be great. But if one is out of alignment with the other, it is best for the one in the back to be a bit lower. 1/64" of an inch lower in the back seems just right to me. My guess is, they meant it to be that way.
For most TS work, plus or minus 1/64" is precision cutting for most people. You can maintain closer tolerances on a TS but you have to work at it.
Marv
Jim Dillon
Brad,
If we are talking about the extension table that is mounted to the rear (away from the operator) of the TS, then you should be fine. As others have said, it is desirable (from a safety standpoint) to have the out-feed extension table just a tad below the rear edge of the TS so boards don't catch as they exit the TS. When I made my wooden extension table, I aimed for 1/16 (2/32) inch below the rear edge of the TS. I hit it pretty close on one side, but it is 3/32 on the other side - a difference of 1/32 inch (roughly 0.03 inches). I was very happy with that and have never looked back. If there are dadoes in the extension table, make sure those are in alignment with the ones in your TS; a piece of wood placed snugly into your TS and extension table dadoes will help with this alignment.
If we are talking about the extension table to the right of the operator, then I would try to get that table flat to the TS top, but I wouldn't get anal about it.
Jim
BradPA
Sorry I did not explain more clearly. I will try again.
The table I am trying to line up is the extension table to the right of the saw and parallel to the fence, and not the outfeed table. Think of this as two planes that I am joining together to make one flat plane.
I am also building a router table into the extension, so I went to the trouble of building a frame underneath the extension to add extra support and to make and keep it flat. Once I put this together to create one bigger plane from two planes, it was impossible because the tablesaw component is not flat and dips a little bit on the outfeed side.
Believe it or not I am generally not too fussy about things like this, but I figure that my woodworking is only as accurate as my equipment so I was trying to be more exact. Also this Unisaw saw replaced a Delta contacter saw and that table was real flat - I never measured because I did not need to, it was just flat and parallel to the extension.
But I think the advise I have received so far is good - basically don't worry about it. My new saw is a discontinued model of the Unisaw that I got for 1/3 the price of a new Unisaw, so I doubt that Delta will do anything for me - It's just frustrating that the new table is much less flat than the old table.
Jim Dillon
Brad,
OK, I think I understand, then again... :) . You are saying that the rear edge of the TS is not level to the front edge. In that case, I guess you could level it by shimming the rear edge (as you suggested in your OP), but I don't think it is worth the effort unless it is easy to do. You are roughly talking about the thickness of four sheets of copy paper (4x0.004). I have the same setup as you are planning with the router in the extension to the right of the operator and like it a lot. Because the right extension is level to the TS top. it ends up being 1/16 inch or so higher than my TS out-feed extension table. Here is a suggestion that has worked out extremely well for me. Instead of somehow trying to join the two extension tables together to make one large, I placed my lunchbox planer into that gap on its own portable bench and then use the TS outfeed extension table also as an outfeed extension table for the planer. This saved on workspace, although one downside is that I have to move the planer (easy to do as it is on wheels) when crosscutting long boards etc. Food for thought!
Jim
PS Sounds like you got a nice TS at an excellent price!
