We value your privacy.
Can you cut a little off the top and bottom and still have enough solid filler block for strength? Using a stud finder or small drill as a depth gauge will tell you how much blocking is there.
Layout the cut lines and then use wide, clear packing tape over the cut to reduce tear out. Choose the right saw blade too. I've used my circular saw and a straight edge. Cut from both sides and then cut the edges by hand.
I used a scraper and chisel to scour away the cardboard material. Then, just glue the blocking back in. It's probably easier to make new blocking than to try and remove the door shell and glue from what you cut off.
I've never cut one down but I'd think it would be awfully unwieldy on a TS unless you've got excellent infeed and outfeed support. A circ saw is probably the fastest but you could probably also use a router.
I've reinstalled plenty of bottoms though. I find it quite easy to just rip a length of 2x4 and glue it in. I don't mess with the original bottom.......but if you clean one up, you can use it as the guide for ripping the 2x4.
Exactly what I do except I use a plywood blade. It seems to tear the wood less. I use a wide chisel to push the cardboard back and clean up the inside edges. Then I just glue wood back in. I make shelves out of old doors because I can get the doors really cheap. I'll rabbit the edges of the replacement wood to cover the veneer on the cut line. The make very nice looking shelves that are amazingly strong.
I've only done this once or twice and I made up a new piece for filling in the bottom. I used masking tape, not painters tape on both sides of the door to limit tear out. Don't use your best blade as there are often nails in the doors. The cardboard honeycomb just pushes out of the way or can be collapsed with the help of a sharp chisel when you put the new block in the bottom.
In addition to the many good tips offered, I suggest that you score the cut line several times with a sharp utility knife and straight edge. Make the cut with a circular saw and straight edge aligning the cut so that the blade edge is in the score line and no tear out will occur.
I've always just used a circular saw and a guide bar to rip off the bottom. I haven't seen any recently that even had any honeycomb in them but it should be easy enough to hack out with a sharp chisel (or router if you are brave). I've always been able to strip the remnants of the skin from the cut-out portion and to then glue it back in place with no problem.
...as there might be metal reinforcing in the internal door stiles. About 25 years ago, I had much thicker carpet installed in my house. Naturally, all the doors would no longer easily close. So I got out my trusty Milwaukee circular saw (still have it), armed with a brand new plywood blade, and had at it. The next thing I know is that there was a lot of noise, sparks, and smoke. Closer inspection also indicated that the new blade no longer had any teeth, or very few. My mistake was trying to take off too much from the bottom of the door. I don't exactly remember how much I was trying to cut off but it likely was around an inch or so. So I only took off a half inch or so on the remaining doors (with another blade) and lived with doors that drag a bit on the carpet. As an aside, those thin-skinned light weight doors sure do make great portable work benches. You've gotten great advice. Go for it!
You didn't tell us which way you wanted to cut it down, Width wise or Length wise or how much. I have cut down many. Both ways. I Ran into corrugated fasteners in one many years ago, but have not seen any metal in one in at least twenty five years. You also did not say how old yours are, but if they are new its unlikely you will hit metal.
I just cut about an inch off two for my son. New ones. In the old days, the skins were three ply plywood and the frames were real wood. On these two, the skins were cardboard with a single layer of veneer on the outer surface and the filler across the bottom was particle board.
What I do is score across the face with a razor knife and cutting just on the waste side of the the line with a circular saw. (Circualr saws cut cleanly onthe bottom and leave tearout on the top surface, and the score line solves that.) If I cut off the filler at the bottom of the door, I either make a new one or use a TS and basically rip the two skins off it and cut it to length and reinstall it. As others have said, the homey comb is easy to push out of the way, but you may have to clean up the glue with a chisel. Once the filler is back in place I clean up the joints and bevel he edges with a block plane or ROS.
