Not scraps.....leftovers
Clint Searl
I just completed this little bench out of leftovers from other projects. It's soft maple, hard maple. dye stain, and NC lacquer. 40 x 18 x 12h A piece of sculpture will be displayed on it.
Clint
Clint Searl
Clint
Re: Not scraps.....leftovers
George Colonel's Workshop-Havertown PA
Good Evening Clint,
Methinks the real display piece is made from your leftovers, not scraps. That is spactacular.
George
FredD
That's a snazzy dye job Clint.
FredD
A.J. Hamler
Clint...
I've always been a proponent of the there's-no-such-thing-as-scrap theory of woodworking.
A.J.
Warren White
That is GORGEOUS! Could you please share the details on the process you went through for the finish?
Thank you!
Warren
Clint Searl
Thanks. The top is some variety of soft maple that starts with a little natural color which I hit pretty heavily with a water based dye stain mixed from red, yellow, and walnut brown. After it dried, I knocked down the fuzz with a maroon scotch bright, followed by two brushed-on coats of thinned nitro cellulose lacquer, again knocked back with 220 drywall sanding screen and the maroon pad, finally finished with two full wet coats of NC sprayed on. After 24 hours, I rubbed out with 0000 steel wool and paste wax, buffed with a tee shirt.
The base is natural hard maple under several coats of sprayed-on NC, steel wooled, waxed, and buffed.
Clint
Better picture
Clint Searl
