Lights Dimming
Lights Dimming
Lights Dimming
Paul Storck
Why is it that when my home airconditioner starts, my lights dim. I understand start-up current draw but... I don't see this happening in other houses.
Re: Lights Dimming
Re: Lights Dimming
R Payne
Two things I've seen that will cause dimming of lights when something big comes on are
1. Not a big enough service to your house (100 amp rather than 200 amp). Usually a condition of older houses.
2. A loose or bad connection. Maybe on the power company's side.
Is it a new phenomenon? If so has anything changed on your end?
How old is the wiring?
ron
Re: Lights Dimming
Re: Lights Dimming
Paul Storck
Thanks. The house is 25 years old. I first noticed it happening last year around the time we had the airconditioner/furnace replaced in the basement, but that could be a coincidence.
Re: Lights Dimming
Re: Lights Dimming
Bruce, a MN Galoot
At this time of year, system voltages are sagging all over. For starters, call your power company and have them come out and measure the voltage delivered to your home. The problem might be on their end.
Re: Lights Dimming
Mine used to
Lee Schierer McKean, PA
With my old heat pump set up, my lights used to dim. We have 200 amp service and all the connections were tight. The problem was starting a big compressor and two blowers simultaneously. I was able to mitigate the problem by adding a time delay relay in the fan starter circuit to delay the fans for a few seconds. When I replaced my old 25 year old heat pump with a new heat pump/air conditioning system last year the problem went away. I still have the same 50,000 btu heat capacity and 4 tons of cooling but the compressor now starts and runs for a short time before the single variable speed fan motor starts. I believe both the compressor and fans have a soft start feature.
Lee
Re: Lights Dimming
Re: Lights Dimming
Tony - Memphis
Mine does that too. Been that way since day 1 (12 years ago). I had evrybody involved check everything and all reported all was well. My shop is a stand alone, but I can always tell when the house ac kicks in - dims the lights out there too. For reference...house ac = 5 ton, service = 200A, shop ac ~1ton / 100A. The house ac is a Goodman and it is the loudest ac unit I've ever heard. When it kicks in, it sounds like somebody hit it with a hammer. Still running fine though - thank goodness - 100�+ here.
Tony
Re: Lights Dimming
Re: Lights Dimming
Bill Turpin in WNC mountains
Is the new unit the same tonnage as the old unit? If it is bigger, then it is pulling more load. Also start components: relays, capacitors, etc. technologies have changed over the years. The actual start loads could have changed on the same size system. As mentioned elsewhere: any added delays should be added to the compressor, not the fans. Most modern outside fans have built-in delays based on head pressure. Delaying the inside fan can cause liquid freon to slug back to the compressor blowing out its valves.
Re: Lights Dimming
Re: Lights Dimming
Chuck Kettler--Greenwood, IN
I had a similar problem and called the power company. They found a bad connection at my head in and fixed it for no charge and the problem went away. Check with them first for sure.
Re: Lights Dimming
Re: Lights Dimming
Paul Storck
Thanks again for all your suggestions. I think I'll start with the power company and eliminate that part of the equation first. It's not the end of the world but it is annoying and the older I get the fewer annoyances I need.
