Bed Construction/Strength Question
Nat Robison
I'm building my son a 4-ft. high loft bed. What supports the bed is a rectangle of 2x6's with plywood screwed to the top. I'm changing it up a bit and using 2x8's with a groove/dado in it with the plywood in the groove so it forms a bit of a tray for the mattress to sit in.
Since we traded in our SUV lease and I took over a 4-door sedan, buying wood is a bit of a challenge. It might not be possible for me to get a sheet of ply home even if they cut it to rough dimension at Lowe's.
Would 1x6 or 1x8 (run perpendicular to the mattress) be sufficiently strong to support the bed and/or if I run some 2x4 "joists" under the planks? Or should I just find a way to get the ply home?
