Watco wipe on poly-not drying
Stephen Kirk
Yesterday, I wiped on a coat of Watco wipe on poly on a red oak bench already finished with 2 coats of dewaxed garnet shellac (love the color). Can states a 4 hour dry time before the second coat, however after 24 hours the boards were still slightly tacky, not enough to leave prints, just a bit sticky. I put them outside in the eastern PA oven today and that seems to be helping.
Anyone else have problems like this? Is using the nice hot sun a good idea, or am I causing other problems. I've had to do this with stain before. It's very humid right now, and that really seems to slow down a finish's drying time.
Oddly enough, the pieces felt good this morning, then got sticky as they warmed up, but now out in the sun the stickiness is going away.
Re: Watco wipe on poly-not drying
bob davis
i had a similar problem with minwax wipe on poly. wrote minwax.the told me humidity is the problem. i agree as th piece was in high humidity area. had no problem since
Glenn Madsen near San Francisco
That makes sense, since poly technically cures and links, rather than 'dries'. Humidity would influence that.
Patience, grasshopper.
Howard Acheson
The drying time on the label is based on 70 degrees and 50% relative humidity. Applying oil based finishes at temperatures and relative humidity above 80 degrees or 80% RH can be problematic. At the very least, flash off and drying will be extended.
One thing you can do is set a fan to keep the air moving over the finished surfaces. Sometimes though, even this will not promote full cure in very high humidity situations.
