REAL MILK PAINT
Shelf Life of Titebond II
Sean Troy
Hi all, what is the shelf life of Titebond II? I've had a gallon jug for two years half full that's been sitting in my shop and been through some hot weather and cold winters. is it time to replace it? thanks, Sean
Re: Shelf Life of Titebond II
Re: Shelf Life of Titebond II *LINK*
Stuart Johnson
There has been some discussion on the Segemented Woodturners site.
Titebond Glue
The Titebond website says the shelf life is one year, but this is a lawyer year (that is, they say it to protect themselves). Someone from Titebond's told me that, until it turns orange and kind of gloppy, that it's still usable.
I admire the confidence of people who have gallon jugs of glue in their home shops; but maybe, after I finish the needed work on our house, I'll be making enough furniture to justify a purchase like that too!
I can vouch for . . .
steve mackay
'bout a year and a half. I store it under the kitchen sink where its sorta cool though. It still acted right.
Sean Troy
It was a gift a couple of years ago and I would never be able to use that much in a year let alone 2. I think it best to play it safe and replace with a pint bottle. thanks for the replies. Sean
Yonak
Likely, the telltale sign of the glue going bad is it turning orange and smelling like some kind of solvent. I had a gallon do that after several years. I took it back to my supplier and they had never seen such a thing before. I figured it was an anomaly until Bill described it, earlier in this thread, as a sign of old age.
Usually my Titebond II just gets thicker with age. I add water and it seems to work fine. Although, really, how would I know if it wasn't working properly ? I never see most of the things I use it on again, but I haven't heard any complaints.
Howard Acheson
Did you check the Titebond web site?
Here's a quote: "Storage life 12 months in tightly closed containers at 75�F." If it's over a year old, why chance it?
Howard Norman-Prescott, AZ
"Here's a quote: "Storage life 12 months in tightly closed containers at 75�F." If it's over a year old, why chance it?
The reason to try to use it would be to save money I would think. For some of us retired folks that is a major concern.
h
Jesse Cloud
Between the lawyerese and the marketing lines, I don't believe much of anything I see on a website or a container. If I have glue that was opened more than a year ago, I will use it on a one-off jig or something, but never on a workpiece. If it smells, it gets tossed. Unless I'm doing a big bent lam project, I just buy it a pint or a quart at a time.
I'm retired but using iffy glue seems penny wise and pound foolish - why risk all that expensive wood, finish, and your time to use up some old glue?
Re: Titebond II easy math
chuckbeck
I use a lot of glue, but here's the math, a 16oz bottle of TBII is about $7.50, a gallon (128oz bottle) is $19 and that's = 8-16oz bottles. $60 and tax is what those 8 bottles would cost in time.
Squeeze ketchup bottles are $.50 apiece or empty pasta sauce jars (FREE!), so buy 8 of those for $4 and pour your gallon off into smaller containers to keep the air out. If can't imagine what you're going to do with all that glue give a few jars away
Howard Acheson
My thoughts exactly, Jesse. Old adhesive and old finish are two areas where being foolishly frugal leads to the possibility of expensive and time consuming problems.
I've been retired over 15 years and was part owner of a large woodworking and custom furniture shop. There were enough problems from non-controllable factors--why inject the potential for problems from controllable factors. The cost of adhesives and finishes are generally a small expense in the overall cost of a project.
Yonak
I just spoke with the Titebond technical support line and got the following information : If the glue is still yellow in color and is a smooth, spreadable consistency it is still good. If it turns orange or becomes rubbery or stringy it's no longer serviceable. If it begins to get less easily spreadable because it's become too thick, you can add up to 5% water to thin it out to a spreadable consistency and it will still bond just as well.
