Cutting slots trick question?
There is a method of cutting slots on a TS for an application such as drawer bottoms. Some method that involves using a standard saw blade and ???? a spacer???? and you can get any slot width you might need to match whatever plywood thickness for the bottoms.
Generally, I am asking how to cut the slots in drawer sides to fit the bottom.
Anybody remember what the trick is?
Re: Cutting slots trick question?
Too easy.....
bill tindall
Cut slot, plane bottom to fit.
John McGaw
I've never found it necessary to use a spacer for a quick-and-dirty drawer-bottom dado cut. Simply cut a slot around all four sides at the desired location with the depth of the blade set suitably [note: I invariably bury drawer bottoms and don't screw them in at the back as some folks do] then bump the rip fence over a bit and do it again then repeat this step as needed to get a dado of the desired width. It isn't even necessary to measure for this method although one can use a bit of scrap to gauge the desired "bump" in a single go. If you were using a really thick bottom then three [four] passed might be needed to get up to 1/2".
I have a really great stacked dado set but using it on my Robland X-31 is such a PITA that I probably have only mounted it ten times in as many years so I almost always do dados with a normal combination blade.
ehgauss
Like he said. Repetitive cuts with combi blade, moving fence as necessary to get width needed.
Regardless of where I'm cutting slots or why, I almost invariably cut a standard width slot (e.g., nominal 1/8", 1/4", 3/8" etc.) that is narrower than the thickness of my plywood, then I rabbet the plywood to perfectly fit the slot. It is toot simple and dead accurate.
Plywood carcases, for example, that for some reason I don't want to use biscuits on, will get nominal 3/8" grooves usually, whether at the ends or the center joints, with mating tongues. Call it an old habit, but you'll never have an ugly open dado seam if you size the tongue correctly, and you'll never need to sweat the thickness of your plywood. It helps to have an overarm router to thickness tongues relative to their bare face. That's the best way to get a uniform thickness, although a tablesaw and a vertical fence will do a passable job.
Chris Friesen
A horizontal router (above the workpiece) or a vertical fence on a router table will also work just fine.
In all cases, the idea is that you use the side not being cut as the reference surface such that thickness variations in the workpiece don't affect the thickness of the resulting tongue.
