Finishing Question
Jerry Draper
Is there any way to warm up the color of hard maple without dyeing or staining? I always get blotching whenever I stain or dye maple.
Finishing Question
Jerry Draper
Re: Finishing Question
George Colonel's Workshop-Havertown PA
Good Afternoon Jerry,
Try top coats of oil based poly, which will impart an amber glow.
George
Re: Thanks George, I'll try it.
Jerry Draper
blotch control Go Here utube video *LINK*
del schisler
Watch the utube viedeo on blotch control by charles neil. This will show you how to control BLOTCH on your wood. The best. also more video's
http://www.youtube.com/profile?user=InTheWorkshop#p/u/4/IfCYMdrP8rM
(Message Deleted by Poster)
Chuck Lenz
You might try a seal coat of shellac. Use Zinsser Seal Coat. Its completely dewaxed and you can put urethane or almost any other finish over it. Also, if you want to get into it you can buy shellac in various shades up to garnet and as long as its dewaxed you can apply whatever over it.
I prefer using dye on maple
both hard and soft. I can warm up the color pretty nicely with that.
Amen to that.....
bill tindall
But, I watched someone stain maple a lovely honey color using water soluble dye and a spray gun. Should the need ever arise, that is what I will try.
And then there is birch!
Steve Schoene
There are a variety of color shades available in shellac that can also warm maple, but which are more color stable over time.
What finish will you be using?
Maple is a strange wood in that oils and varnishes tend to lead to yellowing over time, which is not my favorite look. Water-white lacquers and waterborne finishes tend to preserve the tannish pink color of freshly worked maple. If you want an amber glow, I'd suggest either an amber varnish like Waterlox or some dye stain under your preferred topcoat. On figured maple, some finishers like to stain with a deeper stain, on the brown spectrum, then sand the highlights, leaving color in the end/figured grain to make the effect more striking, regardless of the color or tone of the topcoat or subsequent coats of dye.
Thanks
Jerry Draper
Lots of good info. Thanks to all. I am going to experiment with everything that has been suggested.
John Pappas
Jerry, one thing not mentioned would be the use of a glaze, which is a thin coat of color applied between coats of finish. There are specially formulated glazes for this purpose, but a gel stain can be used. Also, glazes can be made by mixing amounts of linseed oil, varnish, and artist colors or universal colors.
This is a good way to add a bit of color to pine, cherry, and maple. Especially nice with pine because it avoids the color reversal (what was light becomes dark...what was darker becomes the lighter color) that occurs when pine is stained.
