Rikon 10" bandsaw
Paul M.
I rarely post on this forum as I primarily hang out on the hand-tool forum. But I wanted to share a review on my new little powered toy.
I've had a Laguna 14SE bandsaw for many years. The lower saw guide on the Laguna is one of the stupidest designs I've ever seen and requires 3 hands and wrenches to adjust the lower guides to change blade sizes. As such, I've tried cutting curves with wide blades and tried resawing with narrow blades just because I don't want to fight those stupid bearings doing a blade change once again.
I saw the Highland Hardware sale on the Rikon 10-305 10" bandsaw for only $199. This sale has been going on for about the last 6 months. I finally bit and bought one. I figure when I want to cut curves and small items, a 1/4" blade with a small throat is just fine and I can keep the Laguna setup for a 3/4" resaw blade for the big stuff.
My first impressions are pretty good for this little saw. The table is cast iron, and the frame seems rigid enough to hold tension on a small 1/4" blade with no problems. The wheels are spoked steel and run true. The blade is supported with a thrust bearing (blade hits on the outside of the roller not across the face of the bearing) on both upper and lower, with side bearings on each support as well. This is a better setup than cool-blocks as far as I'm concerned. It also has a rack and pinion upper blade guard which is something I wish my Laguna had.
The "trunion" is completely a joke on this saw as I doubt this cast aluminum piece weighs more than an ounce or two. But I will keep this table at 90 degrees to the blade and it seems to lock the table at that setting.
The "fence" is also laughable. You could easily balance this on your pinky without any stress as it is so light. It's difficult to get it clamped down straight as there is so much play in it. But with a little concentration and pushing the fence tight to the rail as you lock it down does work.
The 2-1/2" dust collection is from a port below the lower wheel. It's fine for the small amount of dust that a 1/4" blade will make when cutting nothing bigger than 2" thick (my expected usage, not a tool limitation).
All in all, a good usage of $200 to keep me from fighting the blade changes on the Laguna. I would not make this cute thing my only bandsaw, but it will see lots of use in my small shop making guitar parts.
[Edit]: I forgot to mention a couple of other things associated with this saw:
Another good point: The upper and lower wheel guides can both be adjusted for proper tracking. This is a nice touch for a cheap saw. Most saws in this price range only have tracking on the upper wheel and not the lower.
Another bad point: There is no blade tension guage. These are usually a joke anyways on most cheap bandsaws, so I'll just pluck this and listen for a tone to tension.
