car radiator question
bill tindall
A few months ago I added "Stop leak" to a radiator and indeed it stopped a small seep from where the bottom hose connector is joined to the radiator(plastic to aluminum connection). Also about this time I replaced a thermostat that had been stuck open for a while.
Now, some months later, the temperature is creeping up to 3/4 to 7/8 of the full-scale temperature gauge reading range , where in the past the gauge stayed at 50% of full scale. In the normal amount of driving time the gauge goes to 50% full scale and stays there for 5 miles or so, but then the gauge very slowly creeps up higher and tops out at 3/4 to 7/8 full-scale.
I will take the thermostat out tonight and see if the engine runs cooler. If the problem is not the thermostat then what could be the problem and what to do to fix it?
