We value your privacy.
I've been working on a wine cabinet for my son and DIL for what only seems like forever. The wood (sapele) has been a nightmare, it can't even be scraped without some tear-out. It has fought me every step of the way. I got four boards from a regional lumber supply place, with a sterling reputation. Every one of them has warped as soon as they were cut, and they acclimated in my garage for four months. Should have been enough.
Anyway, this thing is moderately heavy - 48L X 16 D X 41 H, with wine storage in the middle and doors flanking that. It's reminiscent of a large dry sink. Frame and panel ends, and no center support, at least yet.
Here's the question: It's time to put a back on it, but given the weight I'm inclined to go with 1/2" baltic birch. Is that overkill, or should I opt for 1/4" instead? What I'm looking for is structural support, not just a back.
I vote for matching the back to the front doors. If the doors are frame and panel, then the back should be F&P with a center stile, in the same wood and finish. That way, the unit could be displayed free standing.
Knowing the quality of your work, I think you would be disappointed with anything less than an F&P back. However, no need to struggle with the sapele. Use a more machineable wood for the F. Wrap sapele veneer around it before doing the joinery. Veneer some 1/4 ply with sapele for the P.
BTW, if you are getting rough spots on the sapele, even after scraping, a little glue size over the rough spots will even the absorption of the finish....
I'm wondering if you might have gotten some khaya or other African mahogany look-alike, because I've never had any trouble with the workability of sapele, whereas a lot of the others are downright gnarly to work.
As for the boards warping when they were cut, I'm interested to know how they warped: Cup, bow, twist or spring? and how you cut them (rip, crosscut, resaw) to produce the warp. Whatever, the reaction probably had to do with the way the wood was dried, and how it was stored after it was dried. Your sterling lumberyard may have had nothing to do with the original kiln-drying and may have been unaware of any adverse kiln effects. If they stored the wood in a moist location for any length of time, though, it could have set up moisture gradients in the boards that resulted in the warping you observed.
Regarding the back of your wine cabinet, if there's any chance at all that the piece will be a room divider someday, it can't hurt to put a little more effort into the back now, which would include overhanging the top a suitable amount so that it would look correct as a freestanding piece. In that case, you'd want to make frames and panels that maintained the same detailing as the front doors.
If not, and you don't want to put more work than necessary into it, any plywood back will give you the structural strength you need, as that strength is only in one flat dimension, keeping the carcase square; it wouldn't have to overcome twisting forces, so strength in the thickness dimension isn't required. BUT, (and please pardon this pet peeve of mine) 1/4" is too thin for cabinet backs and drawer bottoms because it is never truly flat and it is always flimsy and cheap feeling, especially when you tap on it or bump it with the contents of the case or drawer. Even 3/8" is a better solution, if weight is an object, which I don't think it is in this case.
