Hole in Router Base question....
I have a PC Plunge Router and it has a large hole in the base plate, I suppose to accommodate large bits. It has a three pronged insert you attach with three screws to use a collar. The problem is that there really isn't very much surface area on the bottom of the base. It you are working with small pieces or even trying to round over a corner, its easy to tip the router and let it drop over the end of the piece and thus gouge the surface. I am thinking of making an insert that would fill the space and provide additional support. Anyone know why not? Is a commercial one available?
Re: Hole in Router Base question....
Clint Searl
Clint Searl
Rather than making an insert, I replaced the base on one of mine with a piece of 1/4" Lexan.
Clint
Jesse Cloud
Try Rockler's or one of the online shops for a commercial base. Making your own is also very easy. Just unscrew the old one and use it to locate the screwholes on a piece of mdf, plywood, whatever. Drill and countersink the holes. If your base is thicker than the original one, you will need longer screws. This way you can make the base much bigger, maybe provide for an offset to stabilize the router.
The first plunge will make your base 'zero clearance'.
Also, its not much more work to make several than just one....
Me, too, plus
Bruce, a MN Galoot
with clear Lexan, you get to see through the base and look what what's coming.
You could also use something a bit stiffer, like phenolic.
Piece o' cake!
Plastics
I know very little about this subject, but have been told that different plastics come with different tradeoffs - stiffness, abrasion resistance, etc. I believe acrylic ("Plexiglass," which is one company's trade name for acrylic) is stiffer, but in its normal state easier to scratch, than polycarbonate ("Lexan," ditto re trade name). You can get acrylic that's scratch resistant on one face, though.
All of which is to say, when you seek out the plastic for a subbase, look into the choices.
I do recommend clear, if you can find it, especially if it's scratch resistant. Makes a huge difference being able to see a little better through the cloud of chips the bit is producing. I've never quite known why it took so long for the manufacturers of routers to realize the clear subbases would be better - and even now, only a few of them are shipping routers with clear subbases.
My local plastics retailer (TAP plastics, which is a West Coast chainlet - 20 stores, mainly in California) has a remainders bin, where I've found more 1/4" scratch-resistant acrylic than I'll likely need for the next decade for about $5. You might dig around in the Yellow Pages and see if you've got a local version.
The Borgs or your local hardware store are also possibilities, of course, but the staff are likely to know little to nothing about the functional characteristics of the plastic they sell.
Pat Warner sub bases
Jerry Nicholson
I bought a couple of sub-bases for my Dewalt 621 from Pat Warner several years ago and was very impressed with their quality. They are cut a lot more accurately and cleanly then the ones I have made myself. I am glad to see that Pat is still providing these.
Jerry
A Second to Pat Warner Bases
Stephen
I agree that Pat's bases are very well made, and competitively priced.
Surprisingly, when I ordered one, he said to just pay him after I received it. I don't know if he still uses the "honesty" method of payment, but I was impressed by his trust.
Same here
Tony - Memphis
I got one for my Bosch and it came with a tiny little nub that kept the insert guide from fitting. I told him about just to let him know and he said he didn't expect anything less than perfect and sent me a replacement and told me to keep the original. It is perfectly useable. Lots of good info on his site too. Actually, I've been meaning to order a new plate for my Colt from him. Seems like I saw one there for it.
Tony
Router jigs
Hoa in Alameda
Barry,
For materials - check you local plastic supply stores. They likely have a scrap bin of all kinds of plastics for cheap. That is where I get the materials for my router bases and my tablesaw ZCIs.
For ideas - get a copy of Bill Hylton's Router Magic.
For labor and time - sorry, no help here :)
-- Hoa
Thanks, I made one....
Looked around and had a scrap of acrylic about a 1/4" thick and big enough. Hacked out a rough circle on the band saw. Drilled an 1 1/8" hole through it and then drill a counter bore half way through with an 1 3/8" bit. Turned a scrap of wood on the lathe with a 1 1/8" stub on it. Used double stick tape to mount the blank centered on the stub. Cleaned up the edge and opened up the center hole to match one of the collars. Use the original base to mark the holes of the screws and drilled them. Mounted it and it looks good. Not sure it is dead center, but its good enough for many jobs.
Acrylic is tough to turn and drill. Heats up quickly and becomes gummy. Took some fiddling around to find the best way to drill and cut it. Next one will be better.
used with guide bushing's
del schisler
Re: used with guide bushing's  *LINK*
del schisler
here are some You probly know this . I been doing router's for 15 yrs or so
http://us.oak-park.com/catalogue.html?list=BG--
Jesper, Denmark
Re:Replace it with clear plastic....
Jesper, Denmark
Acrylic is just fine and cheaper than polycarbonate.
It does not have to match the outside profile of the router base either - it is sometimes handy to have a straight edge on the bae to follow some guide set-up.
It is really easy to drill the three screwholes and center hole for the router bit, so you can make several for individual jobs. Use the original baseplate as a template.
Jesper, Denmark
Re: Thanks, I made one....
Jesper, Denmark
Barry, a spray bottle with water in it helps machining the plastic. Just spray a little water where you are drilling or sawing, which keeps the plastic cool, so you do not have to deal with the gummy melted plastic chips.
PC makes other plates...
...for their routers, including one that is predrilled for standard template bushings.
