REAL MILK PAINT
Rushed finish question
Working on a bed for my son And DIL. My son is helping. The head board is a large panel of walnut, 45 X 80". DIL wants it stained and so its stained. Son applied Minwax stain to back side of head board. (I don't understand why he stained it, but he did. Then he applied shellac and then lacquer. While he was doing the, I was distracted by other shop work and life. He has rushed it. In stead of allowing the stain to thoroughly dry (8 hours or so) he put the shellac (Zinsser Seal Coat) on about two hours later and then put the lacquer on an hour or two after that. I am wondering if there is any down side to this and if all these various coats will eventually fully cure? I am suspicious because he leaned one part on another and they stuck together. The good news is that all this on the back side of the head board.
Re: Rushed finish question
Clint Searl
Strip it and start over
Clint Searl
Let the stain cure for several days and lacquer. Shellac intercoat is not necessary.
Clint
Ditto
I've had problems with pigment and NGR stains under lacquer. Eight hours isn't enough lead time, even overnight isn't a safe enough bet. I wouldn't expect this combination that your son applied to cure adequately, if at all, but I guess it can't hurt to wait a couple days and see what happens, since it's on the back of the headboard and won't be seen in any event. If it doesn't dry hard by the time you're ready to finish the rest of the piece, you can strip it then.
Howard Acheson
The biggest issue is whether the excess stain was wiped before applying the finish coats. Minwax Wood Finish oil based stains must have the excess wiped off after letting it set for 15-20 minutes. It then should be allowed to thoroughly dry for a minimum of 8 hours. Not wiping off the excess will cause drying problems with the stain and any finish applied before the stain is dry can have drying problems also.
What I recommend is to give it a couple of days and see if it dries. If so, good. If not, then it should be removed with a chemical paint stripper and start over.
FredD
Try spraying with lacquer thinner and see it it dries before you go to stripping.
May save you a lot of work.
Then substitute lacquer Sanding sealing for the Shellac .
FredD
del schisler
I do a lot of staining . I wait at least 24 hrs before i spray a sanding sealer on . I wape off the excess stain on the start. And after hrs. I go baack and wipe off again. I do this a few time's . It will not show any more that's need's to come off. Than after the 24hrs has passed . I spray a sanding sealer. Which dry's fast. Sand i use 400grit but you can use anything below that. But this grit has been working for yrs. So for me that is ok. Than spray on the lacquer. First coat I let it dry for a couple hrs. Than sand with 400 grit again. Than spray the 2nd coat . That is enough for me. You can spray on a 3rd coat. But it doesn't need it. I use M.L.Campbell . I have use this for a few yrs . Work's for me . It is a cabnet grade. I have never had and problum's with the finish. I use hvlp with 30 lb's of air . No over spray
FredD
Del,
using a low pressure gun with no over spray problems , you should be able to go from the sanding sealer after sanding, though the finish coats without any additional sanding.
Rubout with rubbing compounds would be the next step if you want a absolutely slick finish.
I think if you try 220 Garnet on the sanding sealer , you will find that it levels better and faster. M.L. Campbells is a good product , check into their Vinyl Lacquer base sanding sealer , you will get the benefits of nearly 100% resistance to water vapor entry to the wood.
FredD
