How does Cold Press Glue Compare
Bart Goldberg
Bart Goldberg
To Urea Formaldehyde glue. I've always used the Urea Formaldehyde two part glue for doing veneer work. When I was browsing Woodcraft today, I saw some Cold Press glue from Titebond and thought I've give it a try. Can anyone provide me any understand of how well cold press glue compares?
Thanks In Advance
Bart
Re: How does Cold Press Glue Compare
Bart Goldberg
Bart Goldberg
FYI - The Urea Formaldehyde glue I am referring to is Unibond 800.
Bart
Thomas S Stockton
I didn't really care for cold press glue and prefer regular old titebond for commercial veneers unless I'm dealing with burls. If you need a little more time use the extend version of titebond.
Tom
Experience with "white glue"
bill tindall
When I took a class at Headley's shop in Winchester, VA (http://www.wwotsv.com) I found that the only glue they use for veneering (or anything else) is white glue. Slather it on with a paint brush and slap it in the vacuum bag or cauls. Seemed foolproof.
Jesse Cloud
The main (and huge) difference is that cold press is much safer to use than unibond. Formaldehyde is nasty stuff and the unibond powder is bad news if you breathe it.
When I have a large (for me) veneering project, I will go to cold press. For a smaller project I just use regular titebond.
Some folks that should know told me that regular titebond is formulated to be somewhat flexible even when cured - makes sense for joinery where wood grows and shrinks, but not for veneering. Cold press is supposed to cure to a more rigid state. But frankly, I've used both for lots of projects and can't tell the difference in outcome.
Bart Goldberg
Please Answer the Question Asked.
Bart Goldberg
Ok - I understand that lots of folks use regular PVA glue for veneering - fine. But that is not my question. I want to know how well Tite Bond Cold Press Glue works compared to Unibond 800.
Please answer that question.
Thanks
Bart
Different animals
Titebond cold press glue is a polyvinyl acetate glue, while Unibond is a urea-formaldehyde product, as you already know. The differences are mostly in water resistance, creep and toxicity. PVAs are not recommended for use in exterior or moist locations, while UF glues are very moisture resistant. PVAs creep while UFs don't. PVAs contain minor percentages of toxic ingredients, while Unibond should be used with respiratory protection because of the formaldehyde and fine powder. Unibond has a longer open time -- about 2 hrs at 65� vs 15 minutes for Titebond. They have similar gap-filling properties, and both hold well.
