Reducing Size Of Pictures
Tom Rex
There was a thread concerning this problem on 8/3/10. I submitted a post to that thread but since it was so old I'm afraid no one will answer my post so I will resubmit it in a new post.
I replied to this post
Go here http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
and download image resizer.
I went to this website and on the right side of the page clicked on ImageResizer.Exe.
It did its thing and I clicked on finish.
I clicked Start, All Programs, selected Powertoys for Windows XP and all that was there is a readme file.
What did I do wrong?
Re: Reducing Size Of Pictures
Henry Higginbotham
What you did wrong: Tried to get something useful from Microsoft. :D
Try downloading the image viewer Faststone at www.faststone.org. Not only does the image resizer work well, but it's a very good image viewer as well. Blows away Windows Picture and Fax Viewer.
do a good job posting pictures, and more.......
bill tindall
Step 1 is don't take the pictures at very high resolution to begin with. Then, download a free program from "Irfanview" and post better pictures. Under "edit" you can crop the photo(hold left mouse key down and drag a box around the section to be cropped and then click "crop selection". Under "Image" resize to540x480, a typical screen size. Also under "image" you can adjust contrast under the function "color correction" (the gamma correction seems to work best). Best of all, Under "image", then "effects" then "unsharp mask" you can greatly sharpen the image. Finally, under "file" save it.
This program does vastly more, but that is the bare bones to achieve nice pictures for posting with no expense and little effort.
I think you're okay
Open Windows Explorer, navigate to the photo you want to resize, right-click the file name, and you should get an option to "Resize pictures." Click that option and choose from the sizes available. When you click OK, a resized copy of your image is immediately created in the same folder, with a different name, e.g., instead of IMG_3986.JPG, the copy will be named IMG_3986(Medium).JPG, depending on the format you chose. You can also specify an image size, but you can't specify a file size. You just have to see how big the resized image is. You can also run the command on batches of pictures all at once. Under the Advanced tab, make sure the "Resize original pictures (don't create copies) checkbox is *NOT* checked, or you will permanently alter your originals. I prefer to shoot my originals at the highest resolution my camera will take so I will always have the option of creating high-res prints, while retaining the ability to resize them down to lower-res formats as needed.
I'd call this a rather primitive application, but it is simple and right in your right-click menu, so you don't have to launch an application separately to process photos.
