internal wooden cladding
Amax
Hi, I have just finnished building a wooden outdoor building which I have insulated and put electrics to, double glazed windows etc. The plan is that it will be a workshop and artroom for me and my children. I have lined the interior with tung and groove pine wooden cladding and I am wondering if and what I should treat it with.
Currently I am looking at either using Danish oil, "Liberon Superior Danish Oil" http://www.liberon.co.uk/oil-finishes/gallery_files/site/2136/7731/7746/7750/16528.pdf or a wood wax/oil finnish called "osmo wood wax finish transparent" http://www.ieko.co.uk/files/12/original_wood_wax_finish_transparent.pdf. The osmo finnish according to the manufacturers penetrates the wood as well.
Unfortunately I don't know anything about finnishes and what I should use, or even if I need to use anything at all. I expect that there will be a certain amount of condensation internally during the winter due to the nature of the building. Any advice that you could offer would be very greatfully received.
Thanks in advance. Amax
Re: internal wooden cladding
Clint Searl
Clint Searl
If you expect condensation inside the building, I would be concerned about the window frames, if they are wood, and the insulation. Without a vapor barrier between the insulation and interior wall, water vapor may penetrate and condense in the insulation.
More needs to be known about how the building will be heated/cooled and used and the climate to determine how it should be finished.
Clint
FredD
If your cladding is Knotty Pine for instance , Shellac works well and looks great.
If your insulation is batts with a paper cover facing the room interior, that is good.
If you put a plastic sheet or Tyvek on the outside ,under the siding that is better.
If you put a waterproof membrane like Visqueen on the interior wall face , that is not good, for cold air can travel though the walls from the outside and condense as water behind the warm inside of the Cladding or paneling and get the insulation wet or damp and become haven for mold.
FredD
Steve Schoene
Frankly, I would think of a nearly white paint instead a natural wood finish. It will make the shop dramatically lighter.
2nd that notion..
especially semi-gloss paint.
amax
Hi
Thanks for your replys. The insulation is foil backed and so should repel some of the moisture from the external and there is also a gap between insulation and external cladding to allow air flow. Really what I am trying to decide is what I should treat the internal pine cladding with and I am leaning towards Danish oil but I am looking at the other product mentioned in my first post. Any advice on this would be appreciated
FredD
Amax , we are always ready to assist in a solution and in your case since you have stated your not knowledgeable about the finish for your Pine Cladding, why wander off into the unknown ?
For Pine paneling , knotty or otherwise , Shellac has been the choice for years, because it is fast and easy to spray on , fast and easy to repair and gives a unique warm glow to Pine .
If one were to consider paint , then you might as well used drywall for the interior.
Pine is a attractive wood to use inside and to cover it detracts from its look and feel.
All that being said , if you think your going to have a condensation problem , then you should prepare to avoid that, or Shellac , which won't hold up to moisture ,
Marine Spar Varnish will stand up to water vapor , but it won't protect anything else in the room like tools from rust and degradation.
FredD
Steve Schoene
Marine spar varnish isn't a good choicer, especially considering the prices. Spar varnish is NOT especially moisture resistant, that's not what it was designed for. Spar varnish has to be particularly flexible because spars (masts and booms) and essentially the entire boat moves alot when bounceing around in waves. It also must be flexible because it undergoes wide changes in humidity. On top of that, true marine spar varnish must also resist UV light because that is what causes varnish to fail in exterior applications.
Consequently, if moisture is of concern, a good interior varnish will be more moisture resistant than marine spar varnish at twice the price.
amax
Hi Thank you very much to both of you for your advice so far. It has been really useful.
As suggested, I do want to keep the look of the pine and keep it as natural as possible which is why I chose it in the first instance. I guess the moisture will not be a huge problem, I am just aware that dondensation will occur due to the nature of the building. The reason that I was looking at the two products I picked off the shelf (ie. superior danish oil and oil and wax based product) was that I assumed that I needed something to feed the wood (what ever that means) but still let it breath. sorry if these terms are incorrect but the little reading I did lead me to this conclusion. If this is not necessary then I would be happy to leave it be or put varnish on. Could you by chance offer the pros and cons between Shellac and varnish?
FredD
Amax , a couple of things first, Wood doesn't need feeding or breathing , it is dead.
Those are BS terms dreamed up by Finish manufactuers.
Pros and Cons of Shellac and Varnish.
Each is a good finish for Pine in it's own right.
I prefer Shellac , because it sprays well, repairs easy and recoats in less then thirty minutes. It also is the sealer of choice to block pitch runs from Knots in the Pine , in case the mill didn't "set the Pitch".
It's down side compared to Varnish is it's less tough , though a new coat of Varnish will never have the chemical bond that Shellac does from coat to coat.
Also Varnish brushes nicely with a good Animal hair Brush , but takes much longer to dry.
I recccomend Oil base Varnish over it's lesser water borne form , doesn't swell the grain requiring additional sanding for instance.
Because of the shop environment and possible condensation , if you choose
Varnish , two coats of a Marine Spar Varnish like Heirloom or McCloskey's would look fine , never need recoating .
Either coating is a good finish , choose the one that will fit your interior best .
FredD
