Carpenter ants
Carpenter ants
Carpenter ants
Gary Smyth
The day before yesterday my tallest tree was ripped by the wind in a heavy storm. I lost 65 feet of locust. In the process of cutting the fallen trunk and branches for fire wood several years from now, I found the tree filled with carpenter ants. My wood pile is 50 feet from the house and similar distance from the garage. What can I use to kill the carpenter ants before adding the 18" logs to the stack? I would prefer something safe for dogs and cats. After the logs dry the ants will go away but I don't want to give them a chance to search out the house.
Re: Carpenter ants
Sevin garden spray is what I use...
Grant in Iowa
I have never found anything that claims to be safe for use on firewood, but I have typically split and stacked my firewood, then sprayed it soon thereafter with Sevin spray (newer, less toxic formula than the old stuff) via an included sprayer that goes on the end of a garden hose. I generally "clean up" the splitting area by burning the debris and also spraying that area with the sevin product to kill off the inveriable wood roaches, ants, and etcetera that come home with the load of wood.
I imagine Borax might be safer, but the Sevin is safe enough for use in a vegetable garden, which I figure is good enough for me. I should add that my woodburner draws combustion air from outdoors, and has sealed doors, so it might be inherantly more safe than a different design of woodburner.
Anyway, works for me, but I am all ears for a better solution if someone has one.
FWIW,
Grant in Iowa
Re: Carpenter ants
Re: Carpenter ants
R Payne
Don't count on carpenter ants on leaving once the wood dries. Carpenter ants build their homes in the wood and it having moisture doesn't matter that much to the ants.
Sprinkling borax or boric acid on and around the wood will discourage the ants. if you can raise the temperature of the logs to something above 140 or 150 F, that will encourage the ants to leave the wood, but they will just look for another home.
I've heard that a mix of boric acid and sugar is an ant bait and will kill the ants. I don't know about how it gets mixed however.
Around our house, we use talcum powder around entry points to keep ants out of our house.
ron
Re: Carpenter ants
Re: Carpenter ants  *LINK*
glh17
Not sure if this will help, but I googled "non-toxic way to kill carpenter ants" and got several hits, this is the link from Terminex.
Carpenter Ants
Re: Carpenter ants
Re: Carpenter ants
Since you use will be firewood, cut the logs into firewood length, stand them on end, and pour 1 cup of gasoline into the "nest." in each section The gas and its fumes will sink down the entire length and kill both the ants and their eggs, but then evaporate. Do not, however, try to split the wood for at least 2 weeks after treatment to make sure all the gas has evaporated.
Re: Carpenter ants
Re: Carpenter ants
Mark Salomon
http://www.pestproducts.com/carpenterants.htm
Re: Carpenter ants
Re: Carpenter ants
Jack Prescott
I, ironically, received an e-mail this morning extolling the virtues of "aspartame" (Neutra Sweet artificial sweetner) as the carpenter ant killer of choice!!?? I don't know whether this is a hoax or not but the e-mail says to go to "dorway.com" for more information. I can send you the e-mail if I can figure out how to send it to you??
