Veritas - Innovation in Tools
Question on Threaded Inserts??
I am working on a bed for my son and DIL and have decided to use some threaded inserts to aid in assembly and disassembly. I bought them at the Borg (Lowes), but they came with no instructions. These are smallish, accepting No 10 screws. Outside diameter of the wood threads appears to be about 3/8".
So, What diameter hole to I drill? Do I measure the root diameter and use that or do I use something between the root and outer diameter. They will be screwed into walnut.
Is there a special tool for Installing them? They appear to be set up for a slotted screwdriver.
Re: Question on Threaded Inserts??
I used the 1/4" inserts. They have a interrupted thread. I built a stage bed and used them for the rails. As they had a thread, I used the base diameter of the insert to determine the drill bit size. I got them from the BORG.
Gary Smyth
I use a drill bit only one size smaller than the outside diameter of the insert. Are yours steel or brass? Be careful, in walnut brass will tear up very easily and frustrate the hell out of you. Practice on the wood you will use. Better to be safe than sorry. The best way to install them is with an insert tool and they come in sizes to fit the insert. You will need a steady place to do the insert. They can be tricky to get in straight. You can also use a screw the same size as the inside thread and two nuts and a wrench to provide the leverage. A drill press hand turned is a good way to start the insert. Forget a screwdriver - especially in seasoned walnut. You will want to kill yourself if you use a screwdriver. It's just not worth it. Inserts will work but a #10 screw might be too light depending on where it is used. I'm thinking that a cam set up as used for knock down furniture might be something to consider. They are stronger and easier to install too.
Tom MacGregor
Threaded inserts designed to be installed with a slotted screwdriver can cause problems during installation. If the pre-drilled hole (or the screwdriver) isn't exactly the correct size they can chip or break and be difficult to remove - especially the brass ones. I quit using that type and will only use inserts driven with a hex wrench. They can be cranked into a tighter hole and are far more rugged. Fastenal and McMaster-Carr both carry them in flanged and flush styles. Note that a standard thread insert may require a metric driver. Experiment on some scrap first. They start easier in harder woods with a very slight countersink on the pilot hole, but walnut probably won't need it. By the time you're ready to install inserts you have a lot invested in materials and labor. It's worth using the good ones.
Make an install tool
Grant in Iowa
When I install threaded inserts, I use a drill press and a tool that I make.
To make a tool, begin with a threaded bolt maybe 2" long that will thread into the insert. Then cut off the head of that bolt. Thread on two nuts to the threaded end of the bolt such that there will still be room to thread on one of your inserts. Lock the two nuts together. Chuck the cut end of the tool into the drill press. This insures the insert will be installed square to the wood surface. Turn the chuck by hand unless you happen to have a slow speed reversing drill press such as those found in a machine shop and are skilled at using it.
You can use a good cordless drill in low speed if you are good at holding it square to the work surface.
Experiment with the diameter of the hole required for good results. Each hardness of lumber will require a slightly different hole diameter. Softer wood, use a hole close to the diameter of the inside of the threads. Harder wood, use a slightly larger hole. For Walnut, I'd choose a bit ever so slightly larger than the internal diameter of the threads on the outside of the insert.
I have also found that taking a triangle file and filing some "teeth" in the insert threads can help with very hard lumber like white oak or harder.
Install the insert slightly below the surface to allow tension on the fastener to pull the parts together tightly.
I use them all the time. Love them whatever their type. Especially useful for shop fixtures and jigs.
FWIW,
Grant in Iowa
Re: Make an install tool
Phil Joines
For a #10 insert I'd use either grade 5 or 8 for the bolt. Standard Borg hardware, grade 2, will break.
Carol Reed, Strawberry, AZ
I make the insert 'tool" Grant described. I also slightly chamfer the hole. Otherwise the wood fibers raise around the insert and the whole thing looks sloppy. With walnut I would pick a diameter between the outside diameter and the root diameter. I used my cordless driver so I can reverse. No trouble keeping it straight. I just clamp teh wood so the hole is perpendicular to my tummy. I hold the driver against my body to stabilize things and lean forward, letting the insert screw itself into the wood. Undo the jam nuts and there ya go!
One last thing. The slots for a screwdriver are for taking it out, not putting it in. And few have a larger enough straight screwdriver to do the job without buggering the insert.
My two cents.
Couple things
#10 screws are too small for your project IMO. I'd use at least 1/4-20s.
I make my insert tools from Allen head cap bolts. Cut off a piece of an Allen wrench and glue it into the socket of the cap bolt, then you can easily drive it with your drill/driver. Countersink the clearance hole as Carol mentioned to keep the wood from "volcano-ing" out as you drive the insert home. The chamfered entrance hole also helps start the threading.
Spot on, with one addition-Practice
Bill Tindall
These things look deceptively simple to install but it is easy to get them in not-straight, or not sufficiently deep, if the pilot hole is tool small in diameter. Hence, Practice on a scrap of equivalent hardness.
I wish someone would make a "bottom tap" with the thread size for these things to cut threads into hard woods. In something like maple the pilot holes needs to be almost as big as the OD os the device. I never thought to check but maybe the wood thread is some common size.
Tapping threads first
Tom Dunlap
I read one time that the threads on inserts and some lag screws are the same. Using a lag screw as a tap to cut the threads may work.
I read a shop tip a couple of days ago that showed a clever installer that I'll try to describe.
It's essentially a Drill Guide made from a 2x4.
http://tinyurl.com/376lhmu
The guide looked like a C with the open side down and a hole drilled through the spine of the C. The notch is large enough to accommodate the drive with jam nuts and the insert. I'd add a nylon washer between the insert and the jam nuts to save marring the face of the wood.
Depending on the design and on how stressed the particular parts will be when the bed's assembled, you might consider T-nuts. These are installed on the back side of the piece, relative to where the joint is made, and thus require through-holes and leave the nut exposed at the back side (unless you have enough thickness of stock and time to counterbore and install plugs after you put them in); but in order for this joint to fail, you would have to either pull the T-nut through the wood or suffer massive wood failure.
They're pretty easy to install: drill a through hole the size of your threaded fastener; slightly counterbore the hole on the back side to the outer diameter of the T-nut's barrel; start the nut in the hole, until you can catch threads with a fastener; use the fastener in combination with a mallet to drive them home.
