Recessed ring pulls - source?
I need a source for some recessed pulls (they don't have to be circular).
I'm going to mount them in the stage trap door.
Ideally they will be inexpensive. Ideally I can make "plugs" to fill any holes on the stage floor.
While I'm at it - how about a source for hinges with a minimum barrel. They'd be going in the trap door also.
TIA
Re: Recessed ring pulls - source?
Re: Recessed ring pulls - source? *LINK*
I've used this company (linky below) just once, but was quite impressed by both price and service. You can ask them questions by e-mail or phone, and they'll be quite detailed.
"Flush pull" got me a listing for both one pull (expensive) and a couple of flush hinges. When I asked for "show all matches," I got some much less expensive ring pulls.
"Flush hinge" got me a few more choices in flush-mounted hinges, in which the countersinks are on the opposite side of the barrel. These won't fold over flat - if you need the trap door to lay flat on the stage floor when it's open, they won't work.
If you do need the trap to lay flat when open, you might explore Soss hinges. These aren't cheap, and I'm told are a little fussy to install, but I believe they'll open 180 degrees. I could be wrong...often am.
You probably already know that you shouldn't rely on the hinges to support the trap when closed - stops all around the trap should support it, with the hinges serving merely to hinge.
http://www.greenboatstuff.com/
Gary Smyth
You can use a hinged foot iron made for the stage. Also a heavy duty piano hinge rabbited flush. Flush handles of various weights can be found at nautical hardware dealers. You can use a roto plate lock to lock the door. If your have interest there are two books that might help you for future use. Scene Design and Stage Lighting (Parker, Smith, Wolf) and Stage Scenery (Gillette, and Gillette). I wouldn�t count on cheap hardware. There is too much risk. You can always use it over.
Thanks
The Soss hinges sound interesting. I could do a "frame and panel" door and use them. I would want to use them in plywood.
I found a "filled" ring pull on your link. The price is right and it looks sturdy enough.
Cargo tie downs  *LINK*
Tom Dunlap
Flush cargo tie downs
