A55 Smoothing Plane
Laying out a segment of a very large circle
Bill Tindall
Barry provided the technique to accomplish the task and it is illustrated in the picture. It relies on the fact that the included angle between any point on a circle and the ends of a cord is always the same. So, to lay out the arc of given length and height one glues two sticks together such that they just touch the ends of the cord and the midpoint of the arc as shown in the picture (this operation establishes the constant included angle for this circle and chord length). These points are established with nails driven into the pattern piece. The sticks make the constant angle. To lay out the arc is a trivial matter of rotating the stick assembly from one end of the chord to the other whilst positioning a pencil where the sticks meet, as shown in the picture. (the middle nail must be removed first) In the example, the chord length is 35" and the height is 1" and the circle radius is about 14 feet.
It is commonly thought that a flexed strip will establish the same arc, but in fact a bent strip profile is neither a circle segment nor a parabola, or anything else simple. Indeed, when I positioned a flexed plastic strip over the pattern it was flatter than the arc of a true circle and in my mind not as attractive for this application (bow front drawer).
Thanks again to Barry for this great tip.
(Barty, you should submit this tip to some magazine and win something.)
Re: Laying out a segment of a very large circle
Very useful, but a bit late for submittal
Henry Higginbotham
Published in FWW No. 28 (May/June 1981) under Methods of Work. Just an odd coincidence that I recently bought some old FWWs at a yard sale and happened to see it. I'd imagine that it's been around a lot longer than that, but it was obviously time for a good recycling.
All my best ideas were stolen by the ancients...
FWW from 29 years ago? I surely did not remember that. I actually saw Norm do it within the last year or two, but I already knew it when I saw him do it. Have no Idea how I knew, but I have used it many times.
Glad it worked for you Bill.
Your comments on the spline curves match recollection of them.
I suspect the ancient Chinese stole this as well as the form for any bowl anyone living has ever turned.
Jesper, Denmark
Jesper, Denmark
Bill,
This an established standard method for laying out crowned deck beams and cabintop beams on wooden boats. They all are of different length, as the boat changes width all the way from bow to stern.
