Bandsaw dust collection
wilbur
I have a 1940's era Walker-Turner 16" bandsaw. I just love using it, with one exception. This bandsaw was built in the day when dust collection was pretty much a nonexistent issue. As such, there were no good dust collection devices for this bandsaw.
Some of the solutions that I've seen for this issue for vintage bandsaws have involved using sheet metal to fabricate a hood or cutting a hole in the bandsaw wheel covers to accommodate a dust collection hose. I don't really have a good way of dealing with sheet metal, and I certainly don't want to put a large hole in the cast iron wheel covers of this bandsaw.
A while back I picked up a dust collection port from Woodcraft, and last night I was holding it thinking, "If there was only some way that I could make a dust collection device with this for my bandsaw. But what would I make it from?"
I was thinking this while staring directly at a pile of scrap pine sitting on the floor of my shop. Seriously.
A full ten minutes later: *** headslap ***
This is what I made.
I basically made this by screwing on the right side, putting it under the table of my bandsaw to see what I needed to notch out, then doing the same with the left side, then adding some cross pieces for strength.
On the right side I used a Forstner to drill some recesses, and sloppily epoxied in some rare earth magnets, which will hold it in place.
And this is it in action.
This dust collecting shroud completely encloses the lower guides of my bandsaw, and collects the vast majority of the dust that used to pile up underneath the bandsaw. I can't put a number on it, but I wouldn't be surprised if this setup collects over 99% of the dust generated.
Although this setup is really custom fit for my Walker-Turner bandsaw, the design principles should be easy to apply to any other bandsaw, vintage or otherwise. It's basically a box with an open top and back, with the sides contoured to fit the frame and wheel cover of the bandsaw, and rare earth magnets mounted in an area where they can stick to the bandsaw.
After making this, I'm just a little surprised that more machinery accessories aren't made out of wood instead of fabricated from metal. After all, we are woodworkers, aren't we? :D
Re: Bandsaw dust collection
Jesper, Denmark
Jesper, Denmark
Wilbur, it just goes to show that where there is a will, there is a way. :b
Gerry In North Surrey
Looks good, Wilbur. I made one using a plastic dust collector fitting cutting it to fit around the bottom guide using magnets to hold it onto the bottom of the table.
Gerry
George Colonel's Workshop-Havertown PA
Good Morning Wilbur,
That is a most effective use of scrap pine, and a near perfect solution to your problem. I wouldn't cut a dust port hole in the door if I owned one of those, either.
What did you do with the pine off-cuts? 8)
George
wilbur
What did I do with the off-cuts?
I ran them through the bandsaw to test out my dust collection hood. ;)
Actually, I think it's where there's a Wilbur
there's a way.
FredD
When I look at that machine and it's deluxe manufacture , it is enough to make one misty eyed .. WT was a class act in the woodworking machine business.
Just think , we used to make stuff like that .
FredD
wilbur
I also have a Walker-Turner drill press in great condition, and I used to have a Walker-Turner lathe before I sold it to get a Conover lathe with much larger capacity.
Walker-Turner was a class act, except for the fact that for some reason they liked using very non-standard bearing sizes for their equipment, which sometimes makes rehabbing them kind of an adventure. If my drill press bearings ever give out, I think I'm kind of hosed.
