We value your privacy.
He said that he was concerned about a number of wasps around the property (a single-story detached house). He couldn't locate the nets but thought that they might be under the roof tiles. He has 2 small kids so I understand his concern.
There are wasps around my house too, but I always find the nets and eliminate them.
I've never dealt with "hidden" wasp nets. Should I call an exterminator? What does an exterminator do to find the wasp nets?
I would start by finding exactly what kind of wasps you are dealing with.
The common paper wasp that everybody is familiar with will (in my experience anyway) build a nest where it�s easily seen about 75% of the time. The other 25% will be inside a soffit or attic vent, in electrical boxes and disconnects, etc. Most of the time these wasps won�t bother you if you don�t bother them. The same rule applies to mud daubers, a great wasp to have around if you suffer from arachnophobia. The thing about both of these kinds of wasps is that, even with a relatively large nest, you aren�t likely to notice them that much except very close to the nest.
If someone is noticing a �LOT� of wasps you might be dealing with a species that almost always hides the nest. Yellow jackets. Along with hornets, yellow jackets are the bad boys of the wasp world. They are always aggressive and get more so as the season progresses. Sometimes referred to as ground hornets, yellow jackets will also build nests underground with a surprisingly large entrance hole. The ones with underground nests are easy. Wait until well after dark and pour a quart of gasoline down the hole. If they are in the wall of a building or some similar place call a pro. Even then the results may only be so so - at least that was the outcome when I wanted a nest exterminated at the nursing home where I worked.
Yikes, Randy, that much gas could blow a bomb crater in the ground. I'd urge big-time caution when playing with gas and fire. I've burned out yellow-jacket nests with a few ounces of gas, drizzling a trail of gas several feet or yards from the hole before tossing the match so I could be well away from the explosion. I've also had decent results by just spraying a bunch of hornet spray into the hole, soaking the entryway so any escapees have to walk through the poison to exit the nest. I seem to recall it was a foaming spray of some sort.
Just urging a bit of caution. Your explanation was enlightening, but not as much as your gas bomb would be. If I'm out of school here, let me know.
I agree with Ellis, that much gas can be dangerous and will kill the grass. You can pour about 1/4 cup of moth crystals or moth balls down the hole and plug the hole with a wadded up plastic shopping bag for a few days. Its clean and effective. Do this 1-2 hours after sundown so they are all home and relatively inactive.
As much as I like explosions and fireworks, in this case the gas is simply poured in the hole. The gas itself does the job, there is no need to apply a match.
No that you have brought it up though I guess I�ll have to start looking around for some of the fuse I used to buy for toy cannons. I�ll just have to hope that the nest is somewhere where there was going to be a koi pond or something similar.
If you are encountering a Yellow Jacket type wasp, and they are where you can get to the entrance to their nest, get an insecticide called "Sevin" 5% Dust. You can get it at your local nursery. All it takes is a small scope of the dust sprinkled around the entrance to their nest.
Two years ago I had a serious problem with them. I bought some of this stuff and got up early one morning at first light before the wasps had their coffee and headed off to work. I put some of this Sevin dust around their hole in the ground. Next day, no sign of the little terrorist. It's best to apply the dust early in the morning, not at night. They work long hours and will be returning to their nest even after it starts to get dark.
I learned about this insecticide right here in this message board after posting a question similar to yours.
The Yellow Jackets are the worst kind of wasp because there can be thousands of them in just one nest. They are aggressive and will come at you in large numbers. The only reason I needed to eliminate the three nests that I had a couple years ago was because I was mowing where their nests were. Something like a mower or tractor will really stir them up. Often times they are all over you if you are on a tractor.
I learned that they occupy a nest for only one season, then they pack up their queen and leave. They never occupy the same nest more than once. So if you can tolerate them long enough, they will be gone until next season or they will go off and bug your neighbors.
I have tried all that stuff, WD-40, gasoline, paint, wasp spray, all that stuff. The problem is with the underground Yellow Jackets is, they often times are very deep down and can number in the thousands. You can kill a lot of them using those methods, but you rarely kill them all. I've even tried pounding a rock into the opening to plug it. In a short time they will excavate a new hole around the rock. They are amazing litte creatures.
The only thing I've been successful with is the "Sevin 5% dust" insecticide. It works.
Billy The Exterminator is one of my favorite shows, along with American Pickers and Pawn Stars. Aside from The Woodwright's Shop, these are about it as far as my tv viewing is concerned. LA seems to have more than its share of varmits and critters.
