OT - is treated plywood overkill in this job?
Situation: concrete slab, 6-12" of slab exposed above grade, resting on 4" of gravel and a sheet of plastic. I'm putting down a plastic vapor barrier and screwing down 1/2" plywood (all of this to get a little elevation for drainage where the door abuts on a brick patio). Screwholes will get a shot of poly caulk before the tapcons are driven. All of this inside an enclosed space.
Space will be used as a studio with occasional overnight guests. A floating laminate floor will go on top of the plywood, over the usual thin foam underlayment.
I was planning to put down treated plywood, but am wondering if this is overkill. I realized today that, if I trust the vapor barrier at all, it should be enough that regular CDX ply would be fine, with less outgassing of fumey junk in the occupied space.
Help!
