Love it when a joint comes together
Bill Tindall
With apologies to the "A-team". This panel will be one side of the chest of drawers. It is book matched assembled from some resawed walnut, which in turn is from a log I bought some years ago. In the end I will "like it when the Plan comes together"!
I apply a thin layer of glue to both sides (or one side and rub some onto the other). If the lumber is flat, I start the assembly at one end aligning the boards to be perfectly level with one another, and then lightly tighten the end clamp. I work my way up the joint keeping the boards aligned at each clamp position. After all the clamps are initially set I go back a give each one an additional tightening. I am happy when a tiny bead of glue squeezes out all along the joint.
Re: Love it when a joint comes together
Yes Bill, It Surely Seams Pretty Good
Clint Searl
Beautiful panel
Clint Searl
FredD
Your fitting and clamping procedure works for me, especially the part where you resist the temptation to twist off a clamp handle.
FredD
gary peterson
great looking walnut, I can't get enough.
