Re: Exterior Knotty Alder Doors in Texas
paul in AZ
I don't know alder doors or Texas but have had sailboats for many many years [prior to coming to the desert]
I've maintained teak and mahogany in a full sun, salt water environment which is about as abusive as it gets.
Having tried practically everything suggested my opinion is that the oil finishes look OK for a short while and then go tatty. They are a quick and dirty solution -they do pick up dirt. Once grungy there is little to do except serious sanding to try something else.
Spar varnish would be my choice. A good 3 or even 4 coats of the best quality marine varnish will blow the socks off oils for classy looks and durability. Ask at a marine supply store like West Marine.
It does need looking after, as does any outdoor finish. If it hasn't clouded, cracked, peeled or discolored a very light sanding and recoating every year or maybe two should suffice. A mahogany hull sitting IN salt water can look pretty good for a season or a bit more. Once it has broken down and worn or peeled off it will need some scraping or sanding to get to clean wood if the wood has discolored.
The trick is to recoat it before it has broken down. Then it is pretty easy job.
