REAL MILK PAINT
Walnut splits and checks question
Brian in Brighton
I have some old walnut that I'm using to make a mideival style dining table from and after jointing and planing the stock some of it developed some checks and cracks. Some of the boards have heartwood in them, some don't. SWMBO really likes the cracks and checks and wants to still use the wood. Will it just continue to crack until it breaks apart? It there a way to stop them by filling them in with epoxy? I also thought about adding butterflies, but it's a bunch of them on the 7ft long table.
Re: Walnut splits and checks question
Hmm
You didn't mention the dimensions or moisture content of the walnut, but unless it is very thick and relatively wet, I can't imagine cracks and checks developing. Tell us more.
Michael Wilkins
Photos of large slab tables I have seen have a butterfly or 2 near the end of the slab. This would seem to stop any additional splitting/cracking from tearing the table top completely apart, and would likely enhance the looks of the top.
Dale Lenz
Are you calling...
Dale Lenz
heartwood the center of the tree that contain the pith? If your lumber has the center of the tree, looks like this: (((()))), from the end, grain cracking is Very common and that chuck of wood is normally tossed in my shop.
Re: Are you calling...
Brian in Brighton
Dave, Some of this is in the wood. Blanks are 1.8 thick and 5.5 wide each. Funny thing is that the stock didn't have any of these problems before I jointed them. As far as moisture content, they are 40yr old boards and I've had them in my shop for 5 years here in Colorado. I think most boards here get to 6% or less in that amount of time.
I'll see if I can post some pics.
Indeed
Bill Tindall
It will split and crack until it gets dry (unless it is dried slowly) and then it won't do it any more.
Brian in Brighton
Here are pics of the cracks in some of the boards. Any ideas if the cracks will just keep going, or do I keep the midevil look and fill them in with epoxy??
Well, I'd like to post pics, but I don't want to sign up for some internet thing to place them into and then get even more crap in my inbox from them and I don't see any other way to put pics into threads anymore. I'll check on starting a new thread to see if I can place pics in the new thread, otherwise, no pics to post. :-(
Re: Indeed
Brian in Brighton
I think they are from internal stresses, so I'm not sure what they will do long term. I would like to post pics, but I can't post them to here any longer since I can't upload from my drive.
