Darkening Walnut Sap wood Question??
I have been working on a walnut bed for my son and DIL. Some of the boards have a streak of sapwood on the edge. It would be nice to darken it and get the most out of some of the pieces. Seems a shame to rip it down to eliminate a sliver of white wood. I know that some kiln operations steam the wood to darken the sap. Has anyone tried this on an individual piece? Can it be done? How? Does it require redrying the board?
Any better ideas? Stain? Ebonizing?
Re: Darkening Walnut Sap wood Question??
Steve Schoene
You can dye the sapwood, but it adds a lot of complexity to the finishing process, and there is learning curve to getting it right. I'd recommend leaving it for the scrap bin or for unseen secondary wood.
FredD
If you were Sam Maloof you would leave it white.
FredD
George Colonel's Workshop-Havertown PA
Good Evening Barry,
I generally would incorporate the sap wood into the panel without recourse to dye, if it looked good in that situation. If it doesn't, rip it out and incorporate new heart wood within the panel. I have used aniline dye to match the heart wood when necessary, but it can be problematic getting the test pieces of sap wood to conform. Substituting genuine heart wood seems the most desirable direction to take.
George
contrary opinion
Bill Tindall
Using an artist brush (presuming the sap is not very wide) paint on a brown water soluble stain. Some companies make a brown "sap stain" for the purpose. Practice on a scrap. If you screw up, sand it off and try again. Learning to deal with this problem will save some wood.
I always stain walnut with an oil stain. If I sap stain the sap first it is barely noticeable as a highlight in a panel.
Walnut won't steam darken once it has been thoroughly dry. Small pieces can be steamed in minutes in a pressure cooker/canner.
Jesse Cloud
I usually leave the sap in and apply a stain or dye or a couple of coats using different colors. I don't particularly try to make the sap look exactly like the heart wood, but I want it to be more interesting than just white. A coat of yellow, then some brown will turn the sap a nice tobacco color which provides an interesting contrast to the rest of the wood.
Lee Schierer McKean, PA
I made a walnut china cupboard for my mother a number of years ago. I ran a bit short of walnut and used a couple of pieces with sapwood for the back. I used a walnut sapwood stain and it matched the existing color exactly. That project was at least 15 years ago and the color still matches.
You can also take the husks of black walnuts and make a stain from them. I don't have the exact formula for doing it, but I've heard that it matches the wood closely and is permanent.
Lee
Vincent Booth
Barry,
Thank you for asking this question, I have often wondered about it myself.
And thanks to the guys who provided the great suggestions, I look forward to trying the techniques offered.
Bob Lemon
Barry, a little asphaltum disolved in solvent makes a walnut colored stain. Asphalt is really easy to find. 8)
Kelly Anderson
I just had to figure out the same problem on an aquarium stand that I built this spring. One leg had a pretty good amount of sap wood on one end. I used Deft Danish Oil Finish in Black Walnut. I believe it is the same type of product as Watco. It blended the sap wood in pretty good. You can still see it if you know what you are looking for but otherwise I think that it came out pretty close.
