Veritas - Innovation in Tools
Pilasters Spacing
Pilasters Spacing
Pilasters Spacing
Tom Rex
I'm building bookcases for our church library and I need the shelves to be adjustable.
Therefore, I am using Pilasters imbeded in the plywood uprights.
If the shelves are 9" deep where should I place the Pilasters?
TIA,
T Rex
Re: Pilasters Spacing
Terminology
If I read you right, you're talking about insetting shelf support tracks vertically in the sides of your bookcase(s). I usually think of pilasters as (usually) fluted vertical faux columns on the faces of architraves and furniture. On a 9"-deep shelf, I'd consider spacing them 1" from the front and back edge of the shelves. On deeper shelves, I usually make it a bit deeper, say, up to 1 1/2" or even 2".
I don't think there is a standard for this. It never hurts to play with a mockup to see if there are any unforeseen effects of the placement.
Re: Terminology
FredD
I never heard the term assigned to a part of a Cabinet or Furniture for that matter. In the building industry ,a Pilaster is a rectangular column against a wall with three sides slightly projecting , it may or not be a supporting column.
FredD
A Rose by any other name...
David Yoho
I'm used to seeing this hardware referred to as standards, but I see that Lee Valley calls them pilasters. Either way, you should be fine spacing them an inch in from the front and the rear.
That's what Lowes calls them
Tom Rex
Pilasters
Gary Smyth
I think they are called pilasters by the catalogs because many people do not install them let in to the side panels. They are simply screwed on projecting three sides. Yet another example of a DIY "woodworker" shortcut instead of doing it right.
Re: Pilasters
FredD
If we are talking about a metal strip with slots that accepts shelf supports and are 5/8" wide and 3/16" thick , the manufacturer calls them Shelf Standards as does any Cabinet Maker I know.
FredD
Lee Grindinger
But
Lee Grindinger
Before the 32 mm invasion KV standards were the way I put adjustable shelving in cabs and I used to call them standards as well.
Lee
I have missed the 32mm invasion....
We used to call them standards but actually, I thought they were ratchet strips.
Nomenclature Should Be "Standardized".
Re: But
FredD
Well I had to go here before I could find the #255 Steel Standard with a brass look. I used them all of my cabinet making life , they are still called Steel Standards and if it pleases the company to refer to their Aluminum standards as Pilasters , they have bastardized the term when you consider they are set flush .
If you want a above the panel look , they have a winged standard.
Advertising people who have little or no knowledge about the products they are paid to hawk, muddy the waters if you will.
http://www.knapeandvogt.com/scripts/download_doc.php?prod_id=717&id=830&filename=233%20&%20255%20Series%20Specs%20OL2251%20121509.pdf&filetype=application/pdf
FredD
An idea that's been shelved for too long
John in NM
