Band Saw speed results
Bill Tindall
A while back someone asked how fast a band saw with a big motor could cut. I was resawing tonight and collected a bit of data for the discussion.
The victim was a 7" wide walnut plank 52" long. The saw, a 1954 20" Delta with an ancient 1 HP motor (supposedly what ever kind it is is more powerful than a modern 1 HP motor, I'm told). Blade is 3/4 x 3 tpi Starrett.
It took 30 seconds to slice a piece off the plank. This feed rate was limited not by the motor but by the tooth gullets. Any faster and the saw dust was packing the gullets. A blade with larger gullets (less tpi) would have enabled faster sawing and at some point I would have been motor limited.
I intend to buy a 1.5 tpi carbide for resawing as the steel blades get dull fairly fast.
