Sanding Belts Breaking question.
I have a 4 x 24 portable belt sander. My son is trying to use it to rough sand the big panels I have been posting about. The belts are probably five or six years old and have the wavy joint with the nylon strapping tape over the joint. He is killing them rapidly. They are bursting, sometimes at the seam. He is sliding the sander side to side along the joints. So, the question is, is this bad technique or have the belts aged and are no longer good? Or both.
Re: Sanding Belts Breaking question.
Jim Dillon
Barry,
I also have a 4x24 sander (Bosch) and, yes, I believe the belt's adhesive joint has a finite life. I have a diminishing stockpile of 5-10 year old belts (Klingspor) and the adhesive joints are now failing with little real use. I seem to recall reading about the finite life of these belts somewhere else, but can't recall where.
Jim
Nicholas Tuzzolino
Hi Barry: It doesn't seem to matter who you buy them from, they do have limited shelf life regarding the glue.. I used to buy a bunch at once (real bargain at the time) and end up making sanding blocks out of them..This goes for all sizes. One time I had five boxes of five each of 1 x 42"' belts, all useless.
Moses Yoder
Re: just make sure
Moses Yoder
He is installing them in the correct direction, right? Most belts have an arrow on them to indicate the sanding direction. If they are installed backwards they will burst at the seam.
del schisler
Most likely their are old . The glue has lost it holding power. I bought some 3x21 belt that were new and all 6 came apart. What i found out on my own was they were to tight when i put them on and moved the ever back. It took a min or 2 and they would just come apart. So when you buy belt's from different supplyer's check and make sure their is space at the end roller when you have the lever moved to put belt on. If you have to slide it on with help or it is tight. It probly won't last long. The fellow that i bought the belt's from replace them. And the same thing happen. I went thro a doz and I called them and told them what their problum was. The next replacement worked out fine. That was the first time this happen to me. But i have had some real old belts come apart like yours. I also have a 4x24 sander also. The belts right now are holding up fine. Good luck on the new batch. But check the space on the end roller tho.
