Glue advice needed
Glue advice needed
Glue advice needed
doug f, san clemente, ca
I'm going to mount a very wide, narrow picture to a wall using a french cleat. The picture is 96" wide and 24" high and is matted on 3/16" foam core. It weighs about 15 pounds.
My cleat will be the full width of the picture because it needs the lateral support. I'm making it out of 3/4" plywood so the picture stands out from the wall a bit.
Any suggestions on an adhesive for fastening the wood to the foam core? Epoxy seems like overkill and I hate Gorilla Glue, but I'm wide open to recommendations.
As usual, thanks for the help.
Doug
Re: Glue advice needed
Seems like a job for Mighty Putty.....just kidding, was channeling Billy Mays for a minute.
Actually seems like a job for good quality double stick tape. Turners use it to stick stuff to faceplates, so it should work well for this. Just be sure the cleat has a nice smooth face and kisses up nicely tot he back of the picture. Apply it and gently clamp it for a few minutes, it is somewhat time sensitive. Wood Craft probably carries the good stuff. So does Lee Valley.
Tony - Memphis
That's sort of what I was thinking but with the double sided foam tape. It has just enough thickness to make up for any uneveness between the foam core and the plywood. And there is some that is really sticky.
Tony
Barry - I think you're right on there. I often forget I have a roll of industrial double stick tape that is super thin and comes with a Warning Label to the effect that "use of excess tape could result in a permanent bond." This stuff is sticky!
Tape it is; thanks for the tip.
Doug
Clear Silicone Caulking. I use it to glue in my hand mirrors. When I worked at the Mall they glued up all the signs above each store using clear silicone Caulk. That was 25 years ago and all the signs on stores that never changed are still there.
The weak link in the chain is the paper backing on the foam core. Ideally you need as much surface area as possible to avoid the wood pulling the paper off of the core. We do a lot of work with foam core at work and that's were the failure almost always is.
Clint Searl
PL Polyurethane constructive adhesive
Clint Searl
Jim Dillon
Doug,
Agree with the suggestions of others - all should work. One word of caution though. Make sure you do not apply finish to the side of the french cleat that you are gluing to the foam board. While I can't speak with direct experience regarding construction adhesive, and silicone adhesive, I am currently having problems with double-sided tape and a prefinished surface. So I would be caution regardless of the adhesive you select. Just a thought. Sounds like a neat hanging picture!
Jim
Re: PL Polyurethane constructive adhesive
If you use construction adhesive, test it on a small piece of the foam board in the picture to see it the solvent in the clue discover the foam. Could be a disaster. Actually, test any adhesive you use.
A decision
Thanks everyone for the great advice. There is a development, though. I have found that the picture is not actually mounted on foam core, but recycled PVC. I'm more than a bit concerned that any type of adhesive would contain a solvent that might damage the PVC, so I've decided to go with the two sided tape and see how it holds up.
Updates as they occur.
Doug
Joe Pack
The PL group (i.e., PL400, etc.) makes an adhesive specifically for foam board insulation over wood. I think it is PL200, but I'm not positive. Anyhow, I would guess that every company has their version. I can vouch for the effectiveness of the PL product for foam board, and I can vouch for why you do NOT use the regular product on foam! (Think gasoline in a styrofoam cup...)
The finished product
I thought you folks might be interested in the finished product after all the good advice on adhesive stuff. I went with two-sided tape, the super sticky stuff, and it's holding up so far.
Thanks again.
Doug
Cool picture, Doug
Glad the tape worked out for you. If it starts to sag or give way in a couple years, you can just replace it.
How'd they do that shot anyhow? Is it a composite photo or a painting?
Re: The finished product
Marv
Great picture, Doug, but I think it's a little high on the right... :D
Marv
Re: Cool picture, Doug
Ellis - It's a composite of a seven picture sequence that my son took when we were in Hawaii and printed directly on recycled water bottles. A breaching Humpback whale, about 40 tons of animal all the way out of the water. It's a pretty impressive sight in person.
Doug
I'M AFRAID YOU'LL HAVE PROBLEMS
George Colonel's Workshop-Havertown PA
Good Morning Doug,
Ever consider how that tape will hold up when all of those humpbacks hit the water? that picture will slam to the floor, and probably damage the frame. ;)
George
Oh wow!
Tony - Memphis
That is really cool!
It's probably waterproof tape
or maybe some of that new Gorilla duct tape.
Coming to a stairwell near you! The Uuuultimate Smackdown! The 800-pound Gorilla vs. the 79,000 lb* humpback whale! Nattering on and on and on, I can't remember the rest of the riff because I don't watch wrestling.
*per Wikipedia
