We value your privacy.
It seems that whenever I'm cutting rabbets or dados on the router table the cut ends up "fuzzy" at the corner where the face meets the edge. What causes this? Is this a function of my router bits being dull? Something else? I don't think I'm feeding too fast...any slower and I'd burn the wood.
I get those, too, but it seems to be more a function of the type of wood I'm cutting. I'm currently working with sapele, both solid and plywood, and that fuzzes like crazy. I hand sand the fuzz off and call it good. BTW, my bits are pretty sharp, good quality carbide cutters. I don't have the problem much with harder woods like maple, oak or walnut.
That sounds like it would be a perfect job for a down-cut router bit. The cut you can take with one of these is a bit less than with an up-cut but by pressing the surface fibers down rather than pulling them up it can reduce tear-out and fuzzies.
Since you don't mention what size bits, or wood, it is hard to say exactly, but I'll take a shot.
The point geometry of router bits changes as the cutting circle gets larger or smaller. Smaller bits will have wider cutting angles, because there just wouldn't be enough metal behind the edge to support the edge, so always try to use the largest cutter that you can.
Softer woods need a sharper cutting angle, because the cells are more hollow. With a wider sharpness angle, the cells along the surface are not supported by other cells all the way around, which allows them to bend away and deform, rather than getting sheared off smoothly.
I have an upcut bit, I bought it because I figured it would get the waste out of the channel. I hadn't really thought about reasons for using a downcut bit.
The compression bit is made to cut all the way through something. The bottom portion is upcut and the top portion is down cut. That way you get a smooth cut on both sides of the material.
Both sorts have their place. I've found that down-cut work great for dadoes and rabbets but really stink for making small mortises because the hole fills up with chips and dust almost immediately. Luckily in most mortise applications nobody will see the fuzzy edges, at least if you are sensible and are using shouldered tenons. Haven't tried the combination-cut bits yet -- just haven't come across a need.
As an aside, and be warned that this is something I haven't tried, it seems as though it would be possible to make a zero-clearance baseplate for a plunge router that would keep the fuzz pressed down somewhat when using an up-cut bit. I can't really think of any downside with this idea but I'm sure that there must be one or two.
I think compression bits are intended for plywood (or other woods) with veneer on both faces. Then, you avoid the dilemma of one veneered face being unsupported.
As to the idea of a zero clearance faceplace, how would you see what you're routing? I have a Skil #1823, which has a really wide opening on the bottom. It provides great visibility (but I need to change to a universal faceplate to mount guide bushings). Alternatively, I've use P-C routers that provide a much more limited view of the work and the work piece. How would you see what you're doing with a zero-clearance faceplate? I guess you could use a large template, where the router moves completely within the template.
One thing I have done in the past is to make the edge cuts with a table saw first and a crosscut blade, then use the router to take out the rest. It reduces the amount of fuzzies and gives me a smooth bottom for my dado.
Well, when I'm cutting a dado or a rabbet I'm not freehanding so I don't think "seeing" would be all that important -- following the guide(s) is the key thing. Of course I could be wrong -- it was bound to happen at least once in my life. No, scratch that -- I just thought about my first wife -- make it twice.
Thanks to everyone for their suggestions. I'll have to look at a downcut router bit. Some more specifics for what I was doing, in case that helps any: I was cutting 1/2" wide dados about 1/8" deep with a 1/2" diameter "standard" router bit (i.e. not a spiral bit). I've had this problem in the past routing plywood (birch veneer I think) and the other day I was working with solid birch.
Normally it wouldn't be a problem...just sand the fuzzies off. But in this case, I have a series of regularly spaced dados and the fuzzies affect the accuracy of the next cut, so I'd like to avoid them completely if I can.
