Lightweight Flexible Wood Recommendation
Steven P. Bellner
I am building 19th-century kites using kraft paper and wooden frames. High-tech kites today use carbon fiber rods and lightweight nylon, but I want to make some larger designs using traditional materials.
My question is: what would be a good wood to use that is lightweight, flexible, and generally resists splitting? The wooden stringers are typically 3/16 to 1/4 inch square. Grooves are cut into the ends to hold the outer string, and the grooves are whipped and varnished to prevent splitting. My initial inclination is poplar, but I'm thinking pine or spruce may work equally as well. The only problem with the softwoods is finding stock that isn't loaded with knots.
