Tinting Glue?
Tinting Glue?
Tinting Glue?
Thomas Norton
I have a project going that is made of mahogany. I wanted to use te dark glue but noone local carries it. Have you guys ever tinted glue to darken it up? I am using Titebond.
Thanks
Re: Tinting Glue?
Re: Tinting Glue?
steve mackay
Hair dryer ? When I was useing Titebond (awhile ago) if the temp got around 105 it tended to turn an orange-ish brown.
Re: Tinting Glue?
Re: Tinting Glue?
Joseph Mulherin, Sr
Tom, I just tried a tint of my Titebond 2 glue using some Ceramcoat acrylic pain and it came out the color of the paint nicely. So, if the paint and glue would setup as regular glue it would fulfill your need for the colored glue.
Re: Tinting Glue?
Dale Lenz
Re: Why Tinting Glue?
Dale Lenz
I've been using regular Titebond/II for well over 20 years and don't have glue stain problems, just wipe off what you can, then scrape/sand the rest, never a splotch when it comes to the finish.
Good luck
Re: Tinting Glue?
paul in AZ
My thoughts exactly. If the glue line is properly snug there should be no further need than to use a damp rag to remove most of the squeeze out and later scrape or sand the rest away.
I'd be concerned about the strength of the bond if adding colorings to glue.
I have tried the brownish Titebond and have a purely anecdotal impression that it isn't as strong a glue as the plain variety. I'm perfectly willing to be wrong about that though.
Re: Tinting Glue?
It certainly is possible
Bill Tindall
I would use any water soluble dye, sparingly. The water soluble dyes are charged molecules and stuff with charge can crash a latex, such as PVA glue if enough is added. However, given the strength of these dyes I don't anticipate a problem. I used to buy lumber from a furniture factory that tinted their PVA glue;I can't remember why they did it.
Why do you want to tint your glue?
Re: Tinting Glue?
When in doubt, test it
Bill Tindall
Make a lap joint, let set for a week and bash it. If you get less than about90 per cent wood failure the joint is defective, perhaps because of a glue deficiency.
Re: Tinting Glue?
Re: When in doubt, test it
Jesse Cloud
I called Titebond a few years ago to see if it would be ok to add a little water to keep my glue from drying out so quickly here in the arid desert. The response was that there should be be no problem with 10 percent or less water. So the water based dyes should work ok.
But having said that, Bill is right - test it!
Re: Tinting Glue?
No need to tint.
Steve Schoene
There should be no need to tint glue. A properly fitted and clamped glue joint will show NO glue line. When edge joining boards for a panel just test to see that you have a light tight joint. Just stack two boards on edge and see if you can pass see a light shining behind, holding the boards together with just moderate hand pressure.
