ADVERTISE HERE - FREE TRIAL
(Message Deleted by Poster)
Chuck Lenz
Re: (Message Deleted by Poster)
Re:  Delta 50-760 performance
Not sure I can offer much help. I have a different model DC from Delta. The blower on my sits where your separators and operates in the vertical plane rather than horizontal.
I made a separator out of a thirty gallon roll around Rubbermaid trash can. I use it in the shop when I vac up huge quantities of long stringy shavings off the lathe. I find it works well until the can gets about 2/3's full and then the shavings fly through the can and into the DC. I have not tested it, but I think the coarse heavy stuff drops out in the Separator and the lighter finer stuff ends up in the DC.
I watched yours posts on building the separator and thought is was a great idea. I would suggest there is some sort of design problem if the bag on the DC filled up before the Separator. I think what is going on is that there is not enough separation between the inlet and outlet and the stuff is just flying through the separator. I think what happens in the Cyclone versions is that the dust spins out to the wall and slides down into the drum. Mine is not so fancy, and I think what happens is that the velocity of the air drops dramatically because the trash can is many times the diameter of the pipe and that allows the bigger stuff to fall out. I'm thinking yours has developed a cross connection in the air stream and the air is maintaining its velocity through the can. Is there a baffle under the lid?
As for the fine dust in the filter bag, that is ordinary, I think. Even the cyclones have final filters on them and have to be cleaned occasionally. The "cake" is part of the filter in that it packs up and effectively makes the filter finer, removing smaller particles. Not sure, but the manufacturers probably take it into account for that "1 Micron" statement. They probably rate air flow without the cake and particle size with it.
Jim Rahbe, Bedford Texas
Chuck,
I agree with Barry. I suspect that only the really heavy stuff will stay in your separator. The smaller chips would collect in the plastic bag, and the �dust� would get collected by the filter bag, until you knocked it off and into the plastic bag. I also agree with Barry that the dust collecting in the filter bag is part of what makes the filter work. Appears to me your system is working as designed when using the small chips produced by a table saw. How does it work when sucking up chips from a planer or jointer??
Jim R.
del schisler
I have the same delta I use the 30 gal trah can and the lid i bought from one of the supplyers The only difference is that i have maybe 4 foot of 4" hose in between the colector can and the colector Mine work's very well What i would do is move your unit from under side and put a 4 foot hose in between and see if their is a difference ?? Your's may be to close and doesn't have time to seperate ?? As far as the bag goes I Used to clean mine every 3 bag's full I have cleaned it after 5 can 2/3's full And still working good I would turn it inside out and clean untill very little dust would come out of the bag
Chuck Lenz
Jim DeLaney, Austintown, Ohio
Re:  Caking on bag
I have a huge (36" dia. X 6 feet high) American Felt Fabric bag on my 2 hp DC. AFF's literature specifically says to allow the bag to develop a 'cake' of sawdust on its inner surface, for the best, most efficient filtering. I've had the bag on the DC for about three years, now, and all I ever do is sorta thump the sides of it occasionally. Thumping it does dislodge a bit of debris into the lower can, but the cake never seems to degrade the DC's performance (unlike the debris that clogged the filter cartridge the bag replaced).
YMMV
Jim D.
Re:  Caking on bag
Glenn Madsen near San Francisco
I have pretty much the same setup as mentioned above. My felt bag gets cleaned whenever I feel like it. Since it sits in the back corner of the shop, hiding behind the redwood, I get to it about once a year.
The Rubbermaid drop can gets emptied all the time. I have to clean out the dust bag, the one behind the redwood, once a year, maybe.
Chuck Lenz
Re:  Caking on bag
Actually, I think the one micron rating depends upon the cake building up. Without the cake, I'm pretty sure they let more than one micron pass.
Jim D.
Re:  Caking on bag
Chuck, have you checked the impeller? Every once in a while something gets lodged in mine and I have to reach in there and pull it out. Mine usually raises Cain but sometimes its pretty quiet about it.
My first question is what blade were you using?
Keith Newton----Little Rock, Arkansas
If you are using a rip blade, with sufficient feed rate, most of the chips will be large, and end up in the drum.
If you use a general purpose blade, the chips will be finer, and more will stay air-born further through the system.
If you use an even finer blade, most will end up in the filter.
If you have been cutting with a fine blade, which would fill the filter. Whack it a few times with a small dowel or something friendly to the bag, which will cause it to fall into the bag. This will improve the cfm the next time you need to move the larger chips along the system.
