Router anti-slip pad dots.
Doug Reynolds in Seattle
I have one of the usual router anti-slip pads but, it leaves little round dots on the surface after all my hard work sanding. Will these dots show through and ruin the shellac finish? How do I get rid of the little darlings?
Re: Router anti-slip pad dots.
Bill Tindall
Can't answer your question but I use the mesh shelf and drawer liners/carpet pad. . The stuff is rubbery and looks like expanded metal. They are great. Because of the open structure chips and junk falls harmless through the holes so it doesn't scratch. I put work to be assembled on it, sharpening stones, things to be sanded or routed.
It sounds like something I would sand off before finish
mdclor
I think they will disappear when you vacuum or tack off the piece.
HTH,
Merle
Equally bad experience
Neal in San Jose
I cut up an old router pad for padding in the bottom of a drawer I store hand planes in, and it etched a pattern in the bottom of several cast iron planes. Needless to say when I discovered it, I threw the stuff away. I don't think moisture was the problem, because this is basically a desert and I've had other similar materials that didn't do anything. I think there was a reaction between whatever that pad was and the iron. Good luck getting that off without resorting to resanding the whole piece.
I had trouble.....
with stuff that sounds like what Bill mentioned. Some sort of cheap tan/brown shelf material. Don't know the brand or even where I bought it. My vague recollection is that it was not sold specifically for wood workers but was shelf liner or some such thing.
I use it for a sanding pad and left a piece of work laying on it for a few days and it imparted the pattern to the work. I posted here about it about two years ago and the consensus was that it would not show through the finish, and it did not. However, I don't leave things laying on it for extended periods of time any more, just to be safe. I suspect the substance that left the imprint may have outgassed as well.
del schisler
sure they will show I guess you will have to sand them out Use a ROS I wouldn't use that kind of pad I sand wood on wood I use wood stop's with clamps and have no problum
The why's of the problem
Bill Tindall
Probably the stuff making the spots is plasticizer from the plastic parts. Plasticizers are greasy molecules. I suspect a water based finish would not like to sit upon one of these spots. I doubt there would be any problem with a solvent based finish. But then, doesn't everyone scuff sand just before finishing? which would remove the offending spots.
