We value your privacy.
Typically I cut french cleats with a 45 degree angle and they work fine. But I was wondering; is there any reason they couldn't be cut at, say, a 60 degree angle and work just as well.
Any experience along these lines or any reasons NOT to try it?
It would seem to me that, as long as the angle is steep enough that the cleats aren't inclined to slip out, they should work. 2 degrees off horizontal wouldn't work well, probably - at least not anywhere that the land moves, ever.
I suppose you could make them steep enough that you would run into either grain weakness because of the long bevels, a necessity for excessively wide cleats to accommodate the long runout of the bevel, or excess difficulty in installing - if you had cleats with angles a few degrees off the vertical, you'd probably run into all these problems.
But it would seem to me there's lots of room in the midrange.
It does seem to that, the steeper the angle (actually, measuring from the board, I guess it's the shallower the angle, but I'm thinking of them vertically), the harder to install.
All this is based on no experience whatsoever. I've always cut mine at about 45 degrees, too.
A steeper (greater than 45) angle will be harder to cut. In architectural work, we used to hang panels with 22.5 degree angles to leave a smaller reveal at the top.
I always have cut mine at 45 degrees. My guess is that a 60/30degree cut would probably work okay in a majority of applications. However, the 30 degree cross section has less "meat" across the wedge, and therefore should be weaker. Maybe it is not a good idea to suspend heavy objects like mirrors and hutches/loaded shelves from cleats cut to a 60/30 degree configuration.
If you are cutting them on a table saw it could be that the 45 degree angle would be easier to cut because of the lumber orientation on the fence/table. I don't know about this case but often it is a bit scary cutting acute angles on a table saw because of the way one needs to hold the lumber.
I did not know they were "supposed" to be 45 degrees. I read about them but there was no illustration, so the few I have made have been about 22.5 degrees. That being much less acute and cut on the TS with the board laying flat on the table and frankly did not pay much attention to the actual angle, just kept the two opposing pieces together, one on the wall, the other on the cabinet. The reason I chose the lesser angle was so I could get the cabinet closer to the ceiling after it was hung. If you use a 3/4" thick strip and a forty five degree angle, the closest you can get to the ceiling is about 7/8". With less angle, you can get to less than a half inch. As I said, I only did a few, but they seemed very secure and none has failed even heavily loaded. (That is more a function of how secure they are to the wall and back of the cabinet, I think) If you want to be even more sure, mark the stud locations inside the cabinet and drive a couple of screws through the hanger strip into the studs.
The more vertical the angle is (going from 30 to 45 degrees for instance) the more the downward force of the hanging item will tend to pull the cleat off the wall and off the back of the item being hung, but the more the item has to be raised to lift it off the cleat.
I find 30 degrees up from horizontal (when mounted on the wall) to be a good compromise...enough of an angle that there is no tendency to come off accidentally,while reducing the forces pulling the cleats sideways.
