Dumb question for trash can cyclone lid users
wilbur
If you use one of those lids that you put on a trashcan to make a "cyclone" collector out of the trash can, can you also put a contractor's trash bag inside the trash can at the same time? Or will the bag just get sucked up the exhaust port of the cyclone lid?
Re: Dumb question for trash can cyclone lid users
Clint Searl
Try it and let us know
Clint Searl
DizD
You can do it IF you use something to hold the bag against the sides of the can. I presently use a piece of what I call corrogated plastic sign material (think political campaign signs.) I cut a piece to slightly less than the height of the can, then cut to length which will roughly match the inside circumference. Put the plastic trash bag in, roll the corrogated plastic sign material smaller than the can diameter, insert it and let it go. It will unroll against the sides of the can and hold the bag in place. To empty, pull the corrogated plastic out first and the trash bag is good to go.
(Message Deleted by Poster)
Chuck Lenz
Re: If you do ...
les winter
A slightly smaller garbage can with the bottom cut out will work fine.
I don't have one, so I don't know, but I would have thought it would work without all of the effort mentioned above. Maybe you would have to throw a hand full or two of debris in as a weight in the bottom of the can, but I am pretty sure once you get a couple of inches into it will be OK. At least, I would be happy to try it if I had one. I think the point of the cyclone separator is that the pressure in the can is pretty much neutral or positive and the debris just falls in. There would have to be negative pressure and air flow for the bag to get sucked out.
Here's another thought. Instead of using two trash cans, why not just cut the bottom out of the one you have and put the bag on the outside of that and strap it on with a bungee cord? .
Howard Acheson
Yes the bag will get sucked up unless you devise some method to keep it in. What I did was get a piece of plastic like the kids use for sledding. Insert the bag, roll up the plastic, put it inside the bad and let it unroll. If you have the right size, it will keep the bag open and inside the trash can. Just slightly roll the plastic to remove it when emptying the can.
One guy I knew used a piece of formica but he ran some duct tape around perimeter to prevent the sharp edges from puncturing the bags.
Easy solution
Alan in Little Washington (NC)
Put the trashcan separator on the outlet side of the the blower- between the blower and the filter/bag/direct discharge.
David Hay Denver
I do a similar thing with my shop vac. To keep the bag from getting sucked up against the filter, I put a piece of cardboard in the bin to hold the plastic down. Once the shop vac fills up to a reasonable level, I can pull out the cardboard until it fills up.
David
