Teak, glue and acetone?
Alan Young
Alan Young
A friend wants to make a glider for his wife and wants to know what the best options are for the project. This will be an out door piece so I am suggesting teak for the project. I am about to advise him to use West System Epoxy for the job-I have also seen where it is advised to wipe the glue joint area with acetone just prior to applying the glue -so as to remove the oil from the glue surface. Is this still a recommended practice?
-Alan
Re: Teak, glue and acetone?
Sanding works well also.
I used to wipe oily woods with acetone. There was a discussion on this board a while back. Some wiped with solvent and some didn't. I tried it both ways with some pieces that I was gluing.
In my "trial", wiping with acetone worked. Sanding with 150 grit sandpaper on the areas to be glued also worked.
This was NOT a scientific trial. I had several glue joints that I tried both ways. Three to four does not make a statistically significant sample. Let it suffice to say both appeared to work well. After over a year, all of the joints are holding. The wood I used was also teak.
Clint Searl
Clint Searl
I have epoxied teak without wiping down with no ill effect. However, I wouldn't use epoxy on tightly fitting joints. I would go with Titebond waterproof and bronze or stainless fasteners, depending on the configuration of the joints.
Clint
Tony - Memphis
I made a garden bench out of teak. It is some nasty stuff. It dulls everything within a 100' radius! Beautiful wood and easy to work, but it sure does a number out of edges. It is ridiculously expensive around here too. I used epoxy and wasn't sold on wiping the joints, so some I may have and some I didn't. No issues after one year other than a 100# nephew dive bombing onto the bench and popping a joint loose. I'm not sure why that joint failed - epoxy, solvent? Dunno yet. I haven't taken it aprt to fix it yet.
Tony
