Veritas - Innovation in Tools
OT Computer Chk Dsk Problem
Stuart Johnson
I am running Windows 7 home premium. Yesterday we had a brief on and off power problem and now the p.c. wants to run chkdsk. It hangs up at 1 second and will not complete. I have found what is suppose to be a fix but it calls for running a Microsoft hot fix.
I've downloaded the fix(?) but when I try to run it I get a message saying it can't be run in safe mode. If the computer won't boot up other than in safe mode how do I run the fix?
Re: OT Computer Chk Dsk Problem
Re: OT Computer Chk Dsk Problem *LINK*
Bill Howatt
The chkdsk requirement is usually because the "dirty bit" is set for the disk volume. You can google dirty bit and get lots of info.
Have a look at this and see if setting the X parameter while in safe mode will then let you get into Windows on the reboot. Wasn't written for Windows 7 but Windows 7 is a NTFS file system so it should be valid.
http://forums.techguy.org/windows-xp/465184-volume-dirty.html
Bill
chkntfs command
Stuart Johnson
Thanks Bill, no luck. I could get into safe mode and run it. I then tried to do a chkdsk / f but got a message the volume was in use by another process. I guess it is back to the drawing board. It does get frustrating because it seems it is a known issue that can be fixed by running the fix. The problem is you can't run the fix until it's fixed.
Bill Howatt
When it said it was in use, did it offer to let it run during the next reboot? It can't make changes to the filesystem on C when Windows is running because the disk is in-use so it marks it for running on the next startup before Windows gets going.
Bill
Grant Wilkinson
Bill
You can try this:
Start in Safe Mode.
Click on Start then Run , type cmd and press Enter . Next type fsutil dirty query x: where x: is your boot drive. This queries the drive, and more than likely it will tell you that it is dirty.
Next, type chkntfs /x c: . The X tells Windows to NOT check that particular drive on the next reboot. Now manually reboot your computer, it should not do a chkdsk and should take you directly to normal Windows login.
Once Windows has fully loaded, bring up another Command Prompt and enter chkdsk c: /r . Reply Y when asked if you want this to happen on the next boot. This should take you through 5 stages of the chkdsk scan and will unset that dirty bit. This can take an hour or more depending on the size of your hard drive, be patient and let it complete.
Once booted back to Windows, open another Command Prompt and query the dirty bit again by entering fsutil dirty query c: and Windows will confirm that the dirty bit is not set on that drive.
Stuart Johnson
Thanks Bill and Grant,
I tried both ideas with no luck. I'm also trying find out on a Microsoft site just how to run the Hot Fix that is suppose to take care of the problem.
When I ran Grant's fix the boot didn't take me into chkdsk but the screen just went black with the cursor arrow.
I contacted Dell support. The had me run a system check that is suppose to rule out memory and HD problems. After about six hours it was about 80% complete with no errors. I went to bed and as luck would have it we had a power outage last night so I wasn't able to see the results. The problem with Dell is the first reaction is to wipe the disk and do a re-install of Win 7. I've got a 7/2/10 backup at least in theory. Years ago I faithfully did a back up every week only to find it wouldn't work when it came time to use it. Things have come a long way since then but it does make me nervous. Plus the hassle of downloading and re-installing all the stuff I use like Open Office, WoodTurner Pro. Right now I'm putting my hopes in the Microsoft site unless there are additional ideas.
Bill Howatt
Hopefully you will get it fixed soon and yes, Dell will probably want to restore it to the "Day 1" configuration.
I suggest that after you get it going you use the Microsoft imaging program that comes with Windows 7 to make an image you can restore in case of other problems. There are other programs as well with more features but the MS one will do the basic imaging and since it will use a WinPE version of Windows for the restore you won't be at the mercy of Linux drivers such as used in some other well known imaging programs.
Bill
Grant Wlkinson
Stuart
If you are comfortable editing the registry, here is another fix
http://www.sevenforums.com/tutorials/56685-check-disk-reset.html
Re: OT Computer Chk Dsk Problem update
Stuart Johnson
I feel like I'm in a "is it plugged in" or "did you turn it on" area but the problem is fixed.
I was still trying to find a way to run the hot fix and booted into safe mode. The very first line is "repair computer" then under that are the different options for booting. I though what the heck and clicked the repair line. I was asked to select a couple prompts and the machine went into a fix process. After a couple minutes it said it had made a fix and would rebooted. If it didn't fix the problem it would attempt other fixes. It ran just fine. So after a couple hours on the phone with Dell, over 24 hours of the system running diagnostics it took less than 5 minutes to fix.
I still don't know how to install the hot fix, the clock was 1 hour fast and when I tried to run chkdsk from the start menu it just came up blinked and closed. I tried to run it from cmd but it said it had to be run by a higher authority. My wife is at a library meeting so that is out.
Bill, what is the imagine program you mentioned? Does it work the same as backup?
Thanks for the help.
Bill Howatt
Glad you got it fixed, Stuart. I wouldn't worry about the hotfix.
Windows 7 has a built-in disk imaging program that will make an image backup of your system. Often an external USB drive is used because of the large amount of data being stored - it can be several GB up to a couple hundred depending on the system and the layout.
An image is like a backup except that it will restore your complete disk and it will be bootable. It is like a backup but a backup is often just the files and folders and if your disk crashes you will have to reinstall Windows and the applications and then restore the backed up files and folders. If you have an image, you can restore it to the new disk and you are right back where you were when the image was made.
Having said that, backing up your personal files is the most important aspect of a backup, whether done by an image or just a files and folders backup. You can always reinstall Windows and the apps from the CDs - your personal files such as pictures are available nowhere else at any price.
Other imaging programs are:
Ghost, True-image, Paragon and others. Some like Paragon offer a free stripped down version.
I use True Image and have done so for years but it is one that uses a Linux recovery environment and a weakness is that Linux drivers may not be available for newer hardware or there just may not be a good one for a particular PC configuration. It is essential that you ensure you can do a recovery when the time comes - you don't want to find out that the recovery environment isn't operational on your PC when you really need it. The best way of doing this is to do a test restore to a spare hard-drive. The other recovery environment is WinPE or a variant. This is a Windows environment and the driver issue is less prevalent but like any backup scheme it really should be tested. If I were to bet on any backup program working out of the box it probably would be the built-in Windows 7 one because it is very basic in its features and it likely has the best driver set available.
HTH,
Bill
