Trestle Leg Material
Doug Reynolds in Seattle
I want to make a dedicated sharpening table with a butcher block top and a 4"x4" trestle leg design to replace my Workmate. I was planning on something in the 2 ft by 3 ft size a little lower than my workbench. What are some reasonable options for the frame and legs other than ash, maple, etc.? I could do a lamination but was sort of looking for something that I could buy here in Seattle that would do a fine job without a lot of milling.
Re: Trestle Leg Material
Sharpening station
Gary Smyth
Please excuse not answering your question but your choice for the top is something I'd like to call attention to. Butcher Block is certainly thick enough and heavy enough but having some experience I have to ask what will you sharpen, chisel, lathe tools, bits, knives? Will you do grinding also on that table? Are you dry sharpening or using water and oil? My feeling is that a wood table top will be full of streaked ground-in black filings and spark debris in short order. Is it possible to consider a metal top with a removable cooling pot? Metal will serve you better and be far easier to clean -- but won't look nearly as nice. Do you want or does the table have a vice? Power? Bench dogs for holding the stones? Rubber mat (that won't burn or pit) for vibration? More important is there some method of holding down a squirrely spinning grinder, buffing wheels, belt sander, Tormek or similar? I'm not trying to mess up your thinking. But sharpening will be messy and those sometimes hot filings get into everything.
On the same "wavelength" as Gary - I put a sheet of "shower board" on the top of my sharpening bench.
I can wipe off the shower board and clean it easily. It also is a good material to use as a dry erase board.
Agreed
Bill Tindall
At least laminate counter top, or anything waterproof and nonporous so the debris can be retrieved.
As far as the legs- Fir , pine, spruce. This thing ain't fine furniture.
David Yoho
As far as material goes, I would think you'd have access to douglas fir or spruce. Nothing wrong with either for what you want to build.
I agree with others about the top. I know when I pull out my Tormec, it sits on my maple bench but with a cafeteria tray under it to catch the inevitable water and slurry that spills.
This is for water stones only. I have a commercial butcher block top laying around from another project. I was planning on making something like a smaller version of my cabinetmakers bench. Maybe I'll reconsider the material for the top.
