ADVERTISE HERE - FREE TRIAL
I continue to look for this hinge
Gary Smyth
Anyone know of a source?
Re: I continue to look for this hinge
Rick L
Re: I would say it's proprietary...
Rick L
Got a link to the source so I can find out more about the product. I've been collecting hardware catalogs for over 40 years and never seen anything like that. Other products with their own locking hinges but nothing like that.
Moses Yoder
Moses Yoder
you might just buy the entire apparatus and then take it apart for the hinges. It is probably patented with no hardware available.
(Message Deleted by Poster)
Chuck Lenz
Re: Do you know what it's used for ?
Gary Smyth
Close enough. It's for a laptop computer. It can be used like a bed table or with the legs stretched as a sort of TV tray table. It also folds nicely so it can put into the car and be used outside. Supposed to hold 35 pounds.
Leon
Here is the company that sells the stand.
http://www.laptopdesk.net/wizard-laptop-stand.html
Leon, Thanks.  Another place to call and
Gary Smyth
check. I've found the table for as low as $50.00 + or -, on other sites, but the table comes from (no surprise) China. I cannot locate the source and (again no surprise) the domestic companies selling versions of that table haven't been cooperative in providing that information. I want it for a different application as I want to add an additional "leg". The source you gave me also has a table called a "Mantis" which has a different hinge setup but might also work, but it is even more expensive. By the way Movie/Photo/Theatre houses have light stands that have arms and aluminum extensions that rotate 360 degrees and lock with a screw and saw tooth hinge but they are twice as thick, heavier, and want $99 for only one 4' extension arm and half the hinge.
I'm open for alternatives as long as I can get the option of a full 360 degree rotation and it lays flat.
