OT Any ex-Ma Bell Techs Out There?
Steve in Phoenix
I've got a Western Electric Model 500 that I would like to plug in, but I don't know which wires to hook up to a new plug. It has the original metal retaining harness, and red, yellow, and green wires.
Thanks!
Re: OT Any ex-Ma Bell Techs Out There?
Grant in Iowa
Unless this is a four-wire phone, then the following will be true:
red and green are a pair and yellow/ black are the second pair.
If it is a one line phone, and chances are it was then the red/ green pair should be connected color for color to your phone line pair (which should also be red/green if you have only one line).
If that doesn't work, then it is marginally possible that it was wired to be used as a "line two" such that the yellow/ black are the active working pair. Try the phones yellow/ black wires connected to the red/ green wires on your incoming phone line. Connect the phones black wire to the incoming lines green wire..and connect the phones yellow wire to the incoming lines red wire.
Don't worry about messing up your phone line, as if the telephone company gear detects a problem, it will lock it out for a period of time (usually 15 minutes or so) and then reset it automatically.
If the phone is indeed a four-wire phone (if neither option above works), then you would need a two-wire to four-wire adapter to make it work. Might find such a thing on Ebay.
All of this is from memory, but it should be correct if my grey matter hasn't failed me.
If you need a visual representation, you can google "phone line wiring" and you'll find diagrams to explain it all.
I should add that it is possible if you live in a newer neighborhood (built since maybe the mid eighties) that the telco equipment cannot generate enough ring current to ring the bells on you phone set. If you find the ring to be weak, I'd suggest you don't leave it connected long, as this can be hard on the phone companies gear. Maybe contact them and see if they could provide the right gear to make it work. The odds of them being helpful is probably directly related to the number of grey hairs on the person doing the helping. If they just make excuses and drool on themselves, then seek an older employee to ask for help.
Regards,
Grant in Iowa<---working in telecommunications for over 25 years now
Steve in Phoenix
Thanks Grant.
