We value your privacy.
I'm making a built-in corner cabinet and want to have several pentagonal shelves as below. I can build whatever size I want, but I'd like something close to the dimensions below. Is there a certain size that will maximize the use of a sheet of plywood? Also, is there a safe way to cut the diagonal on a table saw?
From the appearances of your sketch, you have maximized the design already. You can get four of your "shelves" from a half sheet of plywood and eight from a full sheet.
As far as cutting it - I would prefer to use a jig. Much more reproducible, reasonably safe. You can set the 45 degree angle with a stop block. You could then align your piece so that the saw kerf of the sled was at your 4.25".
I agree, the size is good. I like to cut the angle with a router and straight edge. I would roughcut with a skilsaw or sabersaw, then clamp on the straight edge and rout. Once you get one good shelf, use it as a template for all the others with a flush trim bit, or pattern bit. Mabye a good time to buy a Festool saw and straight edge?
That is a typical corner cabinet and the way I always did it was to cut the bottoms and tops and shelves square to their largest dimension, this will give you four to a sheet.
Generally I cut the top and shelves out of Birch plywood , leaving only the bottom cut out of the plywood that you see.
I have a Birch plywood strip 3/4" by twelve inches , by about four feet long .
I laid out a notch in the middle with a framing square about eight inches deep reading the same dimension on each blade of the square held to the side of the plywood , making a perfect 45 degree notch .
This is carefully cut out with a jig saw or a hand saw and you keep the jig for all of this type of cabinet.
Setting the table saw rip fence to a dimension that will accommodate the jig and one of the squares you already have cut,hold the square in the notch with your left hand and run the strip though the saw with you right hand and you will have a nicely cut piece of the corner cabinet that is easily repeatable with the rest of the squares.
Laying out the the first square with a pencil assures you are on the right track when you start cutting..
If you choose this way , think it through and pay attention when you are cutting on the saw. Actually a piece of cake once you get the hang of it.
As Barry mentioned, if the grain orientation is important (i.e. it's not going to be painted), then put the long side of the triangle against the edge of the plywood and make a zig-zag pattern to maximize your plywood usage. With the dimensions you have now, the long side is almost 26", which means you should be able to get 5 triangles out of a strip of plywood (didn't calculate the height of the triangle). If you make the triangles so the long side is under 24" you could get 7 triangles.
Of course, this all assumes I did my math correctly this early in the morning
Consider that nearly every corner you will find in a home or commercial building will not be entirely square, nor will have straight sides. And in my experience at that size shelf, you will find that each one will need to be put in place and scribed to fit the wall very well.
Not sure if it matters for your application, but thought I'd mention this issue before you get things finalized.
Thank you for the good advice. I now know how I'm going to cut them. I can't decide on the size. I think I want to go a little bigger than my drawing. And, yes, I did go look at a Festool. I can't justify it though. I bought a PC circular saw though, and will make do with a homemade guide jig and my router with pattern bit I think.
