Help with Fein Dustex/Turbo 25
I have just received a Fein Dustex (Turbo) 25. After such wonderful recommendations and a terrific reputation, I am thoroughly pissed off and hoping for some help.
Firstly, it comes with perhaps the worst documentation ever. The "manual" is a comic, and this contains NO written instructions. The parts are not numbered and have no reference to text. Consequently I do not know what half the (many) parts are used for. For example, when does one use what filters?
Secondly, it did not come with the paper bag that is in the illustration. Can the vacuum cleaner be used without the paper bag? I do have a Dust Deputy as well.
There is a extremely large fabric-like container (looks like a bowl) that fits over the pleated filter. When is this used? Does it replace the paper bag? It takes up a lot of room - how does one (can one) use this and the paper bag at the same time?
Re: Help with Fein Dustex/Turbo 25
Dave Paine
I have a Fein Turbo I think it it the II. It is the larger unit.
I have had this for 5+ years and have been extremely happy. My first shop vac which is not loud. It is perhaps my only power tool which the wife also likes to use for cleaning out the car.
My unit came with the cloth filter. This sits over the plastic tub. It does work - however it is messy to clean. I always ended up with dust flying all over the place. At the time the paper bag + filter combination was not available.
Last year I purchased the paper bag + filter and would not go back to the cloth filter.
The paper bags does over the side fitting where you connect the hose. The filter goes on the top. A half turn to tighten. The bags are long and fold at the bottom of the tub. The bags last a long time, depending on how much dust/debris you collect.
Now and again a bag has split, and when this happens, you will need the filter.
The filter elements are easy to clean. First with a brush, then I finish with compressed air.
